Old 07-23-2015, 08:55 AM   #1
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
G50 Q45 Differential VLSD R200 w/ 6x1 Output Shafts
G50 Q45 Viscous Differential VLSD R200 w/ 6x1 Output Shafts. Works great! Comes with bearing races.
A MUST HAVE WHEN UPGRADING TO STRONGER AXLES!!! IF YOU PLAN ON PUSHING OVER 450HP THIS IS WHAT YOU NEED!
Can be used in conjunction with the driver side Q45 axle and driver side Z32 TT axle and either Z32TT hubs or Q45 hubs.
$350 shipped.
PM for quickest response.
Old 07-23-2015, 02:45 PM   #2
PoorMans180SX
PoorMans180SX's Avatar
An R200 ring gear will bolt to this? I was under the impression this was an R230, but I haven't messed around with enough differentials to know what swaps.
Old 07-23-2015, 06:59 PM   #3
KiLLeR2001
Trader Rating: (46)
Yes, this is an R200 VLSD that will fit in any S13/S14/J30 etc pumpkin.
Old 07-25-2015, 11:59 PM   #4
KiLLeR2001
Trader Rating: (46)
Bump it up!
Old 07-29-2015, 12:55 AM   #5
KiLLeR2001
Trader Rating: (46)
Bump it up!!
Old 07-31-2015, 01:56 PM   #6
KiLLeR2001
Trader Rating: (46)
Bump it up!!!
Old 08-03-2015, 07:46 PM   #7
KiLLeR2001
Trader Rating: (46)
Bump it up!!
Old 08-04-2015, 10:04 AM   #8
TheRealSy90
TheRealSy90's Avatar
It's tempting to swap to this for the stronger axles and splines, but losing my clutch type lsd for a viscous holds me back :/
Such a good signature.
Old 08-04-2015, 02:12 PM   #9
KiLLeR2001
Trader Rating: (46)
You can always run this for the time being then buy a clutch type LSD that accepts 30-spline shafts. Then you will be able to interchange the shafts between LSD units.
Old 08-06-2015, 11:59 AM   #10
KiLLeR2001
Trader Rating: (46)
Bump it up!
Old 08-06-2015, 12:36 PM   #11
TheRealSy90
I wonder if this would allow you to use 350z axles since they have the same 6x1 pattern.
Old 08-07-2015, 02:53 PM   #12
KiLLeR2001
Trader Rating: (46)
Might be possible, you'll have to compare axle lengths.
Old 08-12-2015, 06:45 PM   #13
KiLLeR2001
Trader Rating: (46)
Bump it up!
Old 08-15-2015, 12:13 PM   #14
KiLLeR2001
Trader Rating: (46)
$325 shipped! Weekend special!
Old 08-19-2015, 10:32 PM   #15
KiLLeR2001
Trader Rating: (46)
Lets get this sold!
Old 08-23-2015, 12:29 PM   #16
KiLLeR2001
Trader Rating: (46)
Bump it up!
