Old 11-08-2004, 09:33 PM   #1
SpdElemts
SpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of light
Starting engine that has been sitting for awhile
Can someone tell me what i should do to prep my engine before i start it up? Btw, it has been sitting for awhile.
Thanks, Jeff
SpdElemts is offline   Reply With Quote
Old 11-09-2004, 03:07 AM   #2
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
well, change coolant, change oil, check all fluid levels, put 2-5 drops of oil in each cylinder and crank engine without spark plugs in so cylinder walls are lubes along with rings.
Old 11-09-2004, 03:00 PM   #3
idlafie
idlafie's Avatar
http://home.sw.rr.com/longstorenissan/archive.htm
Check this guy's webpage out...he lists a lot of good info..he stored his 240 for 3 years!!
If you didn't drop any fuel stabilizer in the gas tank before you let it sit, then you might want to drop & drain the gas tank of all that fuel that is sitting in there now. The attached page gives an explanation of how gasoline deteriorates:
http://www.chevron.com/prodserv/fuel...etecting.shtml
You might want to drain, flush & refill all your other fluids for that same reason also: deterioration & contamination.
And if you didn't jack your car up & put it on jackstands, check your tires / sidewall areas for cracking. The rubber in the tires will break down and start to crack/deteriorate when left sitting in one position for any lenghty period of time.
Anyhow, hope this helps...Good luck!!
ID
Old 11-09-2004, 11:01 PM   #4
SpdElemts
Should i worry about the valve train??
Old 11-10-2004, 04:01 PM   #5
papershot
papershot's Avatar
papershot is an unknown quantity at this point
Send a message via ICQ to papershot Send a message via MSN to papershot
would any of this matter to a car thats been sitting on jackstands for two months?
how long until the gas goes bad? - and would it matter if i added a fuel additive now?
papershot is offline   Reply With Quote
Old 11-10-2004, 04:07 PM   #6
KoukiMonster
KoukiMonster's Avatar
KoukiMonster can only hope to improve
yea like what he said^ l
for instance if you store the car in a garage for the winter. is there anything you need to do when bringing it back out of the garage once summer rolls around?
KoukiMonster is offline   Reply With Quote
Old 11-10-2004, 05:36 PM   #7
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
I swear there is an identicle post out there, from like 2 days ago.
mjjstang is offline   Reply With Quote
Old 11-10-2004, 06:57 PM   #8
AlligatorBling
AlligatorBling's Avatar
AlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choices
Send a message via AIM to AlligatorBling Send a message via Yahoo to AlligatorBling
Seafoam!
AlligatorBling is offline   Reply With Quote
Old 11-10-2004, 07:06 PM   #9
gonzoes14k
gonzoes14k is on a distinguished road
Send a message via AIM to gonzoes14k Send a message via Yahoo to gonzoes14k
Seafoam! Sorry to copy a burg head lol.
"To establish the sports car, you have to race it," Zora Arkus-Duntov
gonzoes14k is offline   Reply With Quote
Old 11-13-2004, 05:11 AM   #10
idlafie
idlafie's Avatar
After a month of not being used it starts to breakdown. It's too late to add fuel additive now. If your car's been sitting on jackstands for about two months, you ought to be okay provided you have it resting on the proper jack points.
ID
Old 11-13-2004, 10:33 AM   #11
amolao
amolao's Avatar
amolao is an unknown quantity at this point
Thanks for the promo, Idlafie......
If your car only sits during winter, a good change of basic fluids will do. No need to get to go deep into a complex operation. Fuel stabilizer,coolant,oil if is a long winter, put up in jacks. The 24E/DE engines are bullet proof, I had a chance to open my engine no too long ago, and there was no sign of any problems, only a little rusty on the coolant channels. In need of a good coolant flush, I did one but I guess it need it a few more....But know is clean and back to normal....Also if you care about your battery, either start the car every now and then or take out and connect it to a battery charger, I used the little ones (motorcycles) and it work fine, they apply a trickle charge just enough to keep it alive..........
http://home.sw.rr.com/longstorenissan ***UPDATED 13 AUG 05 ***
amolao is offline   Reply With Quote
Old 11-14-2004, 11:16 AM   #12
papershot
papershot's Avatar
ID
Chevron gasoline can be stored for a year without deterioration when the storage conditions are good -- a tightly closed container and moderate temperatures. - http://www.chevron.com/prodserv/fuel...term_gasoline/
my car has been sitting for 2 months now, and Im starting it up again in the next couple days. I -think- the gas should be fine. new transmission fluid/oil/coolant too.
Old 11-14-2004, 12:23 PM   #13
AlligatorBling
^ well damn. . . i didnt know that. im gonna start using that in my fourwheeler because i dont run it that much. a tank last forever.
