Sr20det extremely lean all of a sudden
Hey guys my sr20det redtop in a s13 hatch has been running extremely lean out of no where it slowly got there. My afr gauge used to be at the 14-15 range then it went to the 16-17 range and just today went to 19 and 20 the gauge even saids lean once a while now. When i boost it, it runs fine it will boost away no problem. I thought it may have been a boost or vac leak some where cant seem to find any. And i just had new plugs gapped to .32. Ive got a supra twin turbo fuel pump 390lph and i have 750 cc nismo injectors. My fuel pressure is set to 40 psi. Im also running a fuel management system so no iacv. Need help anything works! Thanks!!
I forgot to say it was only at idle it leans out. It will go from 14 ish and then all the way down to 17-19 |
Better yet, do you have a tune?
Have you tried a free air calibration for the sensor?
#8 | |
![]() Join Date: Jul 2005
I Have no idea what you just said and it only makes me that much more suspicious that this is related to your problem. |
Im saying my air and fuel ratio gauge is connected directly to my o2 and my ecu connects to me air fuel ratio gauge. On my air fuel ratio gauge theres 2 wires and ive followed them. And thats what i found
Your AFR gauge has an wideband O2 sensor. If your gauge is hooked to your factory narrow band O2, that is not an accurate means of measuring your O2 reading. If it is indeed a wideband, you should pull it from the exhaust and do a free air calibration on it, if applicable. Your wideband should be connected to the ecu for feedback, so the engine management can see what your AFRs are doing, should your ecu have some type of auto-tune feature.
Fuel management system basically my ecu is trying to idle on its own without a iacv so that has been completely taken out. It uses the mad and o2 to set the car at the lowest possible rating. So that it wont be fricken rich as fk while idling and when boosted it still can deliver super rich fuel. Altho i do have to support it once a while while pulling out of gear or down shifting because it stalls quite easily the idle will sometimes bounce for 1200-2000 and then it will stabilize itself.
#13 | |
#14 |
![]() Join Date: Aug 2009
Sorry dude. You are on your own. You mess with your car. Only you know what is going on with it. Nobody pull their IACV. I hope you know what you are doing. Are you trying to be mad scientist or something. ?
#16 |
Lol I have seem several people who pull theirs...my understanding is its supposed to help it warm up...idle air control valve...the 02 per enthalpy will help with economy, I'm gna replace mine today as mine went lean after 2 years of no issues. I halfway suspect bad fuel for me but I will see!
#18 |
Here is nutshell SOP
1. Install all OEM parts including IACV 2. compression test, boost leak test, tune up: oil/filters/clean the maf/ clean the inlet (wash all plumbing thorough with degreaser and water) wipe everything completely dry before using it again. 3. Disconnect the narrowband oxygen sensor and drive the car. Does it drive normal? You do not need to boost the engine to drive the car normal. 4. Once you see whether the narrowband was fooling the ECU you can replace the O2 sensor, or start changing other parts i.e. maf/ecu/regulator/fuel pump with the fuel pump being next on the list for sudden lean issues besides narrowbands. |
#19 | |
#20 |
A used 16 year old OEM fuel pump with 150,000 miles on it from the first owner, and 50k on it from a second owner? Or you dropped more money on your fuel pump buying a new one than your engine is worth. Either way, I don't make the rules. It could be fuel leak, a ruptured ancient fuel in the tank that finally popped maybe your re-used 18 year old fuel lines with presumably all this pumping power.
#21 | |
Tags |
hatchback, lean, redtop, sr20det |
