Old 11-22-2004, 12:12 PM   #1
FinalDrive
FinalDrive's Avatar
FinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud of
My HID retrofit w/ s15 lights (pics)
I apologize for the piss poor quality pics. They had to be taken with my phone since my digital cam crapped out.
I had to swap out the oem projectors for left hand drive ones so I could get some usable light. I went ahead and upgraded to HID since I was in there. I used a pair of Ecode Valeo projectors from an Audi A4 with brand new oem philips ballasts and 4100K bulbs.
FinalDrive is offline   Reply With Quote
Old 11-22-2004, 12:42 PM   #2
Powashiftin
Powashiftin is an unknown quantity at this point
Can you take some better pictures? Im interested in seeing how they look- those pics don't do it justice
Good work nonetheless
http://www.tempusband.com
Powashiftin is offline   Reply With Quote
Old 11-22-2004, 01:34 PM   #3
FinalDrive
FinalDrive's Avatar
Sure, I'll get some high quality pictures when it gets dark and have them posted by tomorrow.
Old 11-22-2004, 02:35 PM   #4
ThatGuy
Admin Asshole
ThatGuy's Avatar
Find a new host for the High Quality pics, that watermark is friggin annoying. If you don't have anywhere else to host them try http://www.imageshack.us/ . You can host pics up to 1024kilobytes, FREE.
Old 11-22-2004, 03:19 PM   #5
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
s13-15 or s14-15?
I can host your pix if u need btw
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 11-22-2004, 06:45 PM   #6
FinalDrive
FinalDrive's Avatar
s14. I forgot about watermarks for non registered members. I have 4 pics taken tonight....can I email them to you Yoshi?
Old 11-22-2004, 08:26 PM   #7
SilviaDriver
SilviaDriver's Avatar
SilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enough
Send a message via AIM to SilviaDriver
DAMMIT!!! i was gonna do the SAME exact setup!! u beat me to it! damn.
do a write up id like to see how its done. ive been reading on how to do it for over a year now.
SilviaDriver is offline   Reply With Quote
Old 11-22-2004, 08:29 PM   #8
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
mike is gonna be pissed!
wootwoot is offline   Reply With Quote
Old 11-22-2004, 08:30 PM   #9
speeddreamz
speeddreamz's Avatar
speeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nice
Send a message via AIM to speeddreamz
what kind of boost gauge? is that?? Can you do it with s14a??
speeddreamz is offline   Reply With Quote
Old 11-22-2004, 08:48 PM   #10
SilviaDriver
y would he be? this is the same thing he does but at not even half of the cost
Old 11-22-2004, 08:53 PM   #11
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
beam cutoff looks great! Good work!
RBS14 is offline   Reply With Quote
Old 11-22-2004, 11:47 PM   #12
FinalDrive
FinalDrive's Avatar
it a newer Apexi model. I don't see why s14a would pose a problem. I have seen 2 online with retrofits.
Old 11-22-2004, 11:49 PM   #13
FinalDrive
FinalDrive's Avatar
Old 11-23-2004, 09:07 AM   #14
FinalDrive
FinalDrive's Avatar
Here are the cliffnotes, sorry no pictures:
Just take all the screws and rubber pieces off of the headlight then put it in a pre heated oven at 250 degrees for 7 mins. You can leave the rubber strip that goes across the top front. Then carefully pry the lens front lens off with a flat head screwdriver.
Then take the projector mounting plate off by loosening the two adjustment 8mm bolts. Take apart the projector off the oem cutoff shield with a dremel. I used the stock projector's rear reflector cup to mount my new projectors...hard to explain without pics but I cut the cup off and left it's mounting base. The base fit right over the new projector and sandwiched it against the mounting plate. Use locktite on the screws.
I even used the oem s15 shrouds around the new projector lenses so the lights look completely oem.
Put everything back together and use the oven to reseal the lights and the rest should be wiring balasts, etc.
Old 11-23-2004, 09:19 AM   #15
MakotoS13
MakotoS13's Avatar
MakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-known
Send a message via AIM to MakotoS13
you can't just adjust the light angle?
MakotoS13 is offline   Reply With Quote
Old 11-23-2004, 10:09 AM   #16
wootwoot
do i need to buy you a sense of humor for christmas?
and the lightout put looks absolutely great. wish i could see it in person just to see how good it is
Old 11-23-2004, 10:51 AM   #17
old_s13
old_s13's Avatar
old_s13 is an unknown quantity at this point
why would i be pissed, did the guy copy any particular product on my site? no he didnt, therefor i have no reason to be upset. actually, i am happy.. happy to see that someone has taken the time to do what *appears* to be a good job, atleast he researched and put fourth the effort to try this retrofit. how good or bad a job, i dont know. my business is to look after my customers and my projects, not other peoples work.
as for the price, of course when you DO SOMETHING YOURSELF its going to be cheaper, hence the phrase "DIY." you guys DO understand that he's using gutted headlamp components? Its ILLEGAL to sell headlamps that use gutted components of other headlamps. Companies that offer such services can be seriously fined. Our headlamps all use DOT-compliant projectors. You have to PAY if you want to PLAY. I can tell you straight up, any business that sells products that are a liability will end up biting them in the long run.
ps: S15 products arent even listed on our site, we only offer S14 HID retrofit at this point, and are currently working on S13 triple projector retrofit but waiting for new components to become available before we take on such a project.
- Mike / ClearCorners.Com
old_s13 is offline   Reply With Quote
Old 11-23-2004, 09:25 PM   #18
derux
Trader Rating: (22)
derux is making a name for him/her selfderux is making a name for him/her self
Feedback Score: 22 reviews
....waiting for new components to become available before we take on such a project.
Or waiting for them to arive so you can finish. just kidding mike take your time.
derux is offline   Reply With Quote
Old 11-24-2004, 12:06 AM   #19
old_s13
old_s13's Avatar
sorry, your lamps were destroyed and the project was called off. jk
ps: your 510 tail lights are looking massively nice, wait till you see what i have for you! you may want to schedule another trip out here to see it all in person.. heh
