Old 11-21-2004, 04:53 PM   #1
VisionRx7
VisionRx7's Avatar
VisionRx7 is an unknown quantity at this point
Send a message via AIM to VisionRx7
Turbo gasket keeps blowing!
I just finished getting the new manifold on like a week ago, because the gasket between the turbo and mani was leaking. I just got a new manifold to make sure it wasn't warped or anything. I didn't want to replace it with a stock one, so I got one of the redesigned ssautochrome ones (ebay special). The fitment seemed really good. Three days after I had it together, I heard an exhaust leak starting. I knew what it was right away... the gasket between the manifold and turbo. Why is it blowing? Is my turbo warped, or could it just have been a crappy gasket? Should I try one of those stainless ones off of ebay like this one? http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
Thanks for any help,
Jesse
VisionSpeedFactory.com
1993 Mazda Rx7 - 3 Rotor single turbo
VisionRx7 is offline   Reply With Quote
Old 11-21-2004, 06:14 PM   #2
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
I did the same thing, my gasket kept on blowing so I replaced the whole manifold setup, and then the gasket still kept blowing. I found out a good way to replace the turbo on an SR.
You could just unbolt the manifold from the block, and unbolt the turbo/coolant return/feed lines. The turbo will come out with everything as a whole. Tighten ALL the bolts, use lock washers, and when I say tighten, I mean, make it super tight. Some of the bolts are really hard to reach once the turbo is in the engine. Then put the turbo back in there, all bolted together already, and hookup the lines again.
95zilvia is offline   Reply With Quote
Old 11-21-2004, 06:48 PM   #3
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
Make sure that the flange is flat as well. My SSA header flange was warped in one corner about 1/8" before I even installed it.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 11-21-2004, 08:48 PM   #4
VisionRx7
VisionRx7's Avatar
Alright, I'll take it back off again and make sure it isn't warped. I might have just not tightened it enough both times. Thanks for your help!
Old 11-21-2004, 10:18 PM   #5
speeddreamz
speeddreamz's Avatar
speeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nice
Send a message via AIM to speeddreamz
try making sure they're even,sanding them. also make sure that they're clean because sometimes old gasket is left on the flange. Also make sure that the bolts/nuts are tightend down good (be careful not to break um) and then also make sure that metal piece that prevents the bolts from comingoff is on, try locktite too, the high temp red one.
speeddreamz is offline   Reply With Quote
Old 11-22-2004, 12:56 AM   #6
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
besides all that you have to put locking nuts on the 4 studs that go between the turbo and manifold or put some locking tabs...look into in in the search feature alot of people are having this problem....and also if you dont have one get a bracket between your downpipe and transmission....figure all that out and do it right the first time or youll end up doing it once a month or so
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
Old 11-22-2004, 11:01 AM   #7
goodjuan
goodjuan's Avatar
goodjuan is an unknown quantity at this point
Send a message via AIM to goodjuan
I found out i wasn't tightening my bolts very well because they kept backing up...
The exhaust bolts have this chalky surface so it's hard to torque them properly. I cheated and put some grease on all the threads...it was much easier to tighten them down wayy tight. When you run the car for the first time it burns it off...smells a lot. But the bolts haven't backed off since.
This helped me cuz im a pansy. :ghey:
goodjuan is offline   Reply With Quote
Old 11-22-2004, 02:35 PM   #8
VisionRx7
VisionRx7's Avatar
Where would I get that bracket that goes from the downpipe to the tranny? My car is missing it. That might be the problem. Also, since I put the new manifold on, the exhaust is riding on the frame. I used 2 hose clamps to pull the exhaust closer to the tranny for now. That bracket would be a much better choice than the hose clamps, haha.
I used lock nuts on everything, but it was still coming apart.
Old 11-22-2004, 02:43 PM   #9
Vatche
Vatche's Avatar
the bracket u can buy from the dealer for 36 bucks. and the rubber peice is like 14 bucks....i got a bracket with my downpipe....that broke so i have to get another one
i dont know what to tell you about locking nuts backing off...get tabs only thing i havent tryed...and thats stock from factory i would think its the solution
Old 11-22-2004, 03:48 PM   #10
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
Go to the yard and stick it down your pants.
Cost: FREE, unless its a pick n pull where they charge $2 entry
There's another thread about this, some two or three pages down.. basically the nuts back out of the studs from vibrations and such. the metal tabs are weak and dont work. Solutions:
- small tack weld on the nut to keep it from backing out
- weld the gap shut
- get crazy locking nuts from www.stage8.com or whatever
Have fun
kazuo is offline   Reply With Quote
Old 11-22-2004, 10:11 PM   #11
zeek
zeek is an unknown quantity at this point
use loctite on the threads before insertion into nuts.... them bitches arent going anywere after installation.
zeek is offline   Reply With Quote
Old 11-23-2004, 12:44 AM   #12
Vatche
Vatche's Avatar
ok....im talking from experience here....dont weld it, its not worth it....unless you really dont care....and red loctite melts from the heat , it dont work and yeah i forgot you can get a bracket off a stock 240 but where i live you cant find shit at junkyards, someone always gets there first
Old 11-23-2004, 09:48 PM   #13
VisionRx7
VisionRx7's Avatar
I can see what happened now, one of the studs on the manifold pulled out. I'm gonna hit it with some lock tite and use some better lock nuts. My 240 has another problem now... the damn clutch went last night (and I was babying the hell out of it because of this exhaust leak)! It has just been one thing after another, lol! Anyone want a sr20 powered 240 for $5?
Old 11-23-2004, 10:05 PM   #14
S14DB
AFC #1
S14DB's Avatar
I'll give you $4 cause it's an 89...
Old 11-23-2004, 10:34 PM   #15
Vatche
Vatche's Avatar
shit ill sell mine for $3
Old 11-24-2004, 09:32 AM   #16
VisionRx7
VisionRx7's Avatar
Haha, I won't go any lower than $4.50.
Damn Sr20DetMan, If I had $3, I'd buy yours.
Old 11-25-2004, 02:12 AM   #17
kazuo
locktite is worthless on that. I know people whov'e used it and the nuts back out anyway.
Trust me, weld it or get the crazy lock nuts.
Old 11-26-2004, 12:16 AM   #18
Vatche
Vatche's Avatar
yeah you probably invested your last 3 bucks into your car....haha and yes red loctite doesnt do shit it melts and doesnt work....and which crazy lock nuts are you talking about kazuo....there are a ton and im trying to make a final decision on the best one
Old 02-21-2006, 01:43 PM   #19
VisionRx7
VisionRx7's Avatar
sorry to bring this thread back from the dead... I've been working on some other 240s with srs in them pretty often latley... The only thing that I can get to work is tack welding like kazuo said. I went through 4 gaskets in a couple of months until I started tack welding both sides (other side of the stud in the manifold and the nut to the turbo flange). I also put a small tack on the turbo flange and the manifold flange. It makes it a pain when you want to take the turbo off from the manifold, but it keeps them together really well.
Old 02-21-2006, 01:48 PM   #20
Sil-Abc
Sil-Abc's Avatar
Sil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfection
Send a message via AIM to Sil-Abc
just weld it tight cuz i have those stage 8 nuts and they still backed out on me
IM JON WAYNE ESQ.... bitch
Sil-Abc is offline   Reply With Quote
Old 02-21-2006, 06:08 PM   #21
FRpilot
FRpilot's Avatar
does that bracket that connect the dp to tranny help? does it lower vibrations or something? my blitz dp came with one but i didnt put it on.
FRpilot is offline   Reply With Quote
Old 02-21-2006, 06:47 PM   #22
g6civcx
g6civcx's Avatar
The SSAutochrome manifolds I saw were terrible. Every single one of them. The design is bad. The workmanship is bad. It looks like they just grinded down some pipe and welded them together.
If you're looking for a cheap alternative, I recommend staying with the stock cast iron manifold. If you really insist, try the Megan Racing manifold for $150. Those seem to be okay. The first-gen had some cracking problems, but they fixed that and the second-gen doesn't seem to crack as badly.
Or if you have the money, HKS for a grand
Old 02-21-2006, 06:52 PM   #23
dvdevo
dvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enough
does anyone know if having a small length of flex piping on the downpipe would keep the stress from the exhaust a minimum?
dvdevo is offline   Reply With Quote
Old 02-22-2006, 12:01 AM   #24
VisionRx7
VisionRx7's Avatar
Just welding it and using the tranny brace seemed to help a lot... the tranny brace kept it from vibrating against the frame. You shold be able to find a flex pipe at pretty much any exhaust shop.
Old 02-22-2006, 12:26 AM   #25
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
fuck it if it keeps backin off get a small drill bit , drill a hole and safety wire the bitch.. to something with in the same area.. or just safety wire all of the nuts/bolt connecting..... we do that alot on our drain plugs... on our race engines... and tranny and diff nuts...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 02-22-2006, 10:15 AM   #26
battery1882
battery1882's Avatar
battery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enough
I had the same problem and it did not go away until I took the manifold to machine shop and have the turbo flange machined perfectly flat. I would also recommend tacking the nut with a welder.
battery1882 is offline   Reply With Quote
Old 02-22-2006, 11:30 AM   #27
Vatche
Vatche's Avatar
so yeah i posted all sorts of comments on this thread like years or so ago...and i havent had a problem since. the bracket solves this bullshit. thats my input. if u dont have one get one. once u get this it should solve all problems. if it doesnt...then u can go from there
Old 02-22-2006, 01:02 PM   #28
VisionRx7
VisionRx7's Avatar
yea, I was just following up saying that the welding and the bracket solved it... I had it that way for about a year without any problems before my engine blew... then I had to grind the welds off to get the manifold off, lol.
