Old 02-17-2016, 04:39 PM   #1
89sileighty
89sileighty is an unknown quantity at this point
E-brake for s13 clarification
I know throwing R33 GTST brakes on a s13 is direct bolt up in the rear with s15 5 lug hubs, but does the E-brake cable match up in length?
Searched around and still have mixed understanding as everyone claims its too long or too short or perfect.
Thanks for any help.
89sileighty is offline   Reply With Quote
Old 02-17-2016, 04:48 PM   #2
derass
Z32 2+2 cables for S13
R33 cables for S14
Old 02-17-2016, 04:58 PM   #3
89sileighty
R33 cables for S14
Awesome, thanks man!
Old 02-17-2016, 05:11 PM   #4
89sileighty
sorry, just to clarify. So the setup should be:
s15 rear hub
R33 GTST brake assembly
z32 braided brake lines
z32 2+2 e-brake
Done?
Old 02-17-2016, 05:30 PM   #5
derass
You can also use S14 or Z32 N/A hubs. Maybe from Skylines too, not sure on that.
You can use Z32 brake lines with some custom work, but it's easier to use conversion lines.
This page is a good start: http://importnut.net/300zxbrakeswap.htm
Old 02-17-2016, 05:45 PM   #6
89sileighty
Ok sounds good, thanks for the help.
So just get z32 conversion brake lines and z32 2+2 e-brake and they attach fine to the R33 gtst brake assembly just fine?
Sorry for all the questions man, I'm planning it this weekend and just want to get it done as smooth as possible. I appreciate the link also.
Old 02-17-2016, 06:25 PM   #7
derass
You'll also need the bracket to adapt the Z32 cables to the S13. The ones I have aren't available anymore, but I found this on eBay, same idea:
http://www.ebay.ca/itm/SIN-NISSAN-RP...-/111644926272
Here's another pro-tip: Have a dremel or die grinder with a sanding drum ready. The hole on the S-Chassis knuckle where the anchor block mounts will be rusted and needs to be cleaned up.
Old 02-17-2016, 06:40 PM   #8
89sileighty
Awesome, I appreciate all the help. Hopefully all goes smooth.
