Old 02-24-2016, 06:29 PM   #1
Turb
Turb's Avatar
Turb is an unknown quantity at this point
SR20 Boost But NO POWER
So I finally go my sr20det back together blowing and changing the head gasket, it starts up fine, idles fine, and besides a little lifter ticking doesn't sound bad at all.
But... when I took it out to drive it for some reason it just doesn't have power it hits full boost at 2500-3000 ish rpm but kinda bogs down just feels like its really sluggish? Any ideas on what it could be? Checked all my plugs look good running a little rich but nothing major, turbo is in good condition no shaft play, could it be major boost leaks?
Possibly timing?
What do you guys think, I should check?
Thanks.
Turb is offline   Reply With Quote
Old 02-24-2016, 06:36 PM   #2
Tyler_240
Tyler_240 is an unknown quantity at this point
Verify your base timing, check your MAF (Clean it very carefully) and you can use carb cleaner around your IC piping and if it changes the idle, you know you got a boost leak...
Tyler_240 is offline   Reply With Quote
Old 02-24-2016, 07:35 PM   #3
Turb
Turb's Avatar
What do you mean if it changes the idle? like when I spray it at my couplers or week spots in my boost system?
Old 02-24-2016, 09:09 PM   #4
KAT-PWR
KAT-PWR's Avatar
KAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really nice
Lack of power and rich sounds like the knock sensor is being tripped. Check timing as mentioned. Do a boost leak test.
MRP Manufacturing
KAT-PWR is offline   Reply With Quote
Old 02-24-2016, 10:19 PM   #5
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
You sure it's lifter tick and not an exhaust manifold leak?
Old 02-24-2016, 11:17 PM   #6
!Zar!
!Zar!'s Avatar
Sounds like a loose exhaust manifold/turbo.
Old 02-25-2016, 04:32 AM   #7
Tyler_240
Correct. I didn't think about the knock sensor, but that's not a horrible idea. It's located underneath your intake manifold way up on the block. You can unplug the harness temporarily.
If you have solid mounts, it could be receiving false knock and retarding your timing from the vibrations.
Old 02-25-2016, 05:20 AM   #8
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
Same thing happened to me. Knock sensor. Go check the ecu for codes
corkscrew is offline   Reply With Quote
Old 02-25-2016, 07:01 AM   #9
Turb
Turb's Avatar
It could be loose exhaust mani or elbow I have like 2 studs on my elbow
Old 02-25-2016, 09:06 AM   #10
thegr8one013
thegr8one013 is an unknown quantity at this point
is hitting full boost at 2.5-3k normal? was this the same as before?
if you were hitting full boost at an earlier rpm before it could be a boost leak somewhere. if theres no boost leak it could be a mechanical timing issue.
i havnt dealt with sr20s but if their cas are adjustable then it could be ignition timing being off.
thegr8one013 is offline   Reply With Quote
Old 02-25-2016, 12:23 PM   #11
Turb
Turb's Avatar
ECU threw code 55 so I assume its not my knock sensor?
Ill check for boost leaks and exhaust mani
Old 02-25-2016, 04:21 PM   #12
Kingtal0n
Kingtal0n's Avatar
probably timing setting or knock sensor as many have already suggested
Old 02-25-2016, 07:26 PM   #13
Turb
Turb's Avatar
Well since I set my timing to spec off the fsm and the ecu threw no codes for knock sensor it's probably not that...
Old 02-25-2016, 07:49 PM   #14
Tyler_240
What we're saying about the knock sensor, is only going to be a problem with at speed...if its the problem...sounds like you have some other maintenance issues, a.k.a. fix those exhaust studs...if you have a solid mounts, or a lot of vibration at WOT, that is when the knock sensor is going to act up and retard your timing
Old 02-25-2016, 07:56 PM   #15
Kingtal0n
Kingtal0n's Avatar
You cant go by codes. they help sometimes but... put it this way, Ive never checked a code on an Nissan. Ever.
Old 02-25-2016, 08:35 PM   #16
Turb
Turb's Avatar
So only way to know if my knock sensor is bad is by replacing it..?
Old 02-26-2016, 07:07 AM   #17
corkscrew
corkscrew's Avatar
A lot of the time something in the sub harness will go bad
Old 02-29-2016, 05:47 PM   #18
corkscrew
corkscrew's Avatar
Ever figure out the issue?
Old 03-16-2016, 03:42 PM   #19
mando240
mando240 is an unknown quantity at this point
I am curious to know if you got the issue under control.
instagram.com/NissansFinest
mando240 is offline   Reply With Quote
Old 03-20-2016, 01:32 PM   #20
Turb
Turb's Avatar
Looks like the new cometic headgasket I got is garbage and need to get a new one
