Old 03-09-2016, 05:04 PM   #1
caanglin
caanglin's Avatar
caanglin is an unknown quantity at this point
RHD JDM 1988 Mitsubishi Galant VR4
1988 JDM RHD Mitsubishi Galant VR4
$8,000 obo
1988 JDM Galant VR4.
Engine
STM fuel pump rewire
3" Catless turbo-back
K&N cone filter
Suspension
Ground Control Coilovers
KYB AGX Struts
Wheels/Tires
Rota Grid 17x8 +35 4x114.3
Interior
Apexi boost gauge
Momo Race 350mm
Maintenance at 95k
Timing belt kit
Spark plugs
Redline transmission fluid
Redline transfer case fluid
OEM Mitsubishi rear end fluid
Maintenance at 99k
Oil change
Oil return pipe
Maintenance at 108k
Front axels/cv's
Tie rod ends
Oil change
Front brake pads
The good. Low miles 113k kilometers. Very solid mechanically. It's my daily and hasn't left me stranded in the year I have had it. Everything works as it should other than the rear windows don't sometimes go up with the driver window switches you have to use the ones on the rear doors.
The bad.
The worst thing about the car is the paint but it isn't too bad. Also needs an idle control valve sometimes will die at stop signs and red lights. Ordering new one.
caanglin is offline   Reply With Quote
