Old 04-02-2016, 08:51 PM   #1
Slide_ways14
Slide_ways14's Avatar
Slide_ways14 is an unknown quantity at this point
Send a message via AIM to Slide_ways14 Send a message via MSN to Slide_ways14 Send a message via Yahoo to Slide_ways14
Track/Drift Lexus GS300 Rolling Shell Forsale.
1999 Lexus Gs300 (CLEAN TITLE) with pink in hand
Chassis is track ready for any type of engine of your choosing and it is ready to go, Car handles amazing with the full cage and suspension. It's already manual swapped. Every part that i listed below will be included. Probably some stuffs not listed, but my loss is your gain.
3in one piece Aluminum Driveshaft for 1jz/2jz R154 with Aluminum differential adapter- $700
Welded Rear differential with a 1/2 in plate- $200
Aluminum Radiator/Samco Hoses for 2JZ-GE - $200
Dual Flex a Lite Fans - $200
A/c lines and Condensor - $100
Aeromotive Fuel Pump 340lph - $200
Custom -an fitting stainless lines for the Fuel feed and fuel return -$60
Drift motion -6AN in line Fuel filter - $20
Custom aluminum power steering reservoir -6AN return -10AN feed - $100
-6AN stainless steel lines for the steering rack both return and feed - $80
Suspension: All suspension parts Under 3000 miles
Powerd by max coil overs 22kg 20kg - $800
40mm front RCA - $120
New inner and outer tie rods - $60
New lower ball joints - $60
Top speed front under brace -$ 180
SPC front upper control arms - $400
Front and rear blue TRD stabilizer bar - $500
Battle version Aluminum steering rack bushing - $60
Battle version rear upper control arms (Track version) - $600
Battle version rear toe arms -$200
Battle version rear traction arm - $200
Battle version solid differential bushings - $120
Interior:
Full custom 6 point weld-in cage - $2500
NRG short hub -$80
NRG quick release - $80
Momo 350mm deep corn leather - $140
ASD hydraulic e brake & custom lines - $320
Joe's Racing rear view mirror - $60
1100watt CRUNCH amp - $60
1000watt Kicker 12in sub - $60
Battery relocated to trunk -$40
Exterior:
Authentic BN sports full body kit - $2400
OEM Toyota window visors - $200
OEM Toyota chrome door handles - $250
Depo LED taillights - $300
Serial nine rear quarter panels - $500
Custom hibino style fenders - $350
Toyota aristo Front grille - $100
Custom purple amethyst pearl with gold flakes- $2500
Brakes: - $1500
Front- (under 500 miles)
Stoptech rotors
Rear- (under 500 miles)
Wilwood 4 piston BBK
Wilwood 324mm rotors
Wilwood brake pads
Wilwood stainless steel lines
"if sparks don't fly your rides to high"
Slide_ways14 is offline   Reply With Quote
Old 04-03-2016, 02:29 AM   #2
CaliforniaMayhem
CaliforniaMayhem's Avatar
CaliforniaMayhem is an unknown quantity at this point
Are you parting out? For ppl who might be interested, how much for everything?
Sent from my SM-G900V using Tapatalk
CaliforniaMayhem is offline   Reply With Quote
Old 04-03-2016, 10:29 AM   #3
240 kouki
240 kouki is an unknown quantity at this point
I think he wanted 10k for the while shell. You might as well just buy the whole shell with the parts if you wanted everything.
240 kouki is offline   Reply With Quote
Old 04-07-2016, 08:54 PM   #4
Slide_ways14
Bump to the top
2jz, aristo, drift, gs300, v300
