Old 05-24-2016, 05:45 PM   #1
Holdmydrift
Holdmydrift is an unknown quantity at this point
KA S14 KA24DE swap! Help!! No power to ecu
Hey guys I've been on these forums for years but I finally decided to actually "join"....anyways I'm this close 👌🏾 to just selling this P.O.S I can't figure what's wrong with it.
93 240sx hatch 5speed
Okay originally this had a redtop SR in it which I swapped and wired it in myself but then years later I blew it up (what a surprise) and now I threw in an s14 KA and followed the whole guide of doing the s14 KA into s13 chassis like s13 engine harness, s13 dizzy, s13 intake/exhaust mani, s13 ecu etc etc
The problem I'm having and I can't seem to figure it out to save my life; the ecu is not turning on at all, the red led doesn't come on with the key on, doesn't crank, fuel pump doesn't prime and of course there's no spark. CEL doesn't turn on either, there's 3 connectors coming from the body harness kinda close to the fuse box in the engine compartment that I can't seem to figure out where they plug into, like stated below I've true 2 different harnesses on and neither of them had a plug for any of these mystery connectors
I've checked and very thoroughly the following
• checked all the fuses and relays (I jumped each relay individually and they all clicked when applied +/- , I checked the Ohms of each relay and they were all within spec (thanks FSM) and pulled each fuse individually also and they were good.
• triple checked every connectors in the bay just to see if they were loose or corroded
• have tried 3 different ECUs so far, one s14 and 2 s13
•jumped the EGI pump relay to see if the ecu turns on and nothing happened
• checked power wires/ ground wires at the brown plug next to the ecu and the brown plug in the bay and they were good, 12v were needed and ground were needed.
• checked ignition switch and is good, 12v coming out of the wires and is actually new I replaced it about year ago
• checked all the grounds and connected all the grounds from the engine harness and from the sub harness, even made new grounds for the hell of it
• I've tried 2 harnesses so far, s13 one and a s14 one both 5 speed if it matters and no progress
I ran into a wall with this easy ass swap, I don't know what else could it be anymore PLEASE HELP
Another weird thing, I plugged in my SR ecu in with the KA harness for the hell of it and the ECU led actually lit up and the CEL came on as well but no start of course but just found it weird
And sorry I know it's really really long but I tried ruling most of it out in one shot to keep this thread short
Holdmydrift is offline   Reply With Quote
