Stock s14 clutch replacement help?
My s14 has the stock clutch from 1995 and its slipping badly. I'm a noob so I don't know if there's anything I can do other than replacing the clutch. So one, should I replace the clutch? And two, what options do i have for replacing it if do?
![]() Join Date: Jun 2003
Trader Rating: (130)
1: yes
2: http://lmgtfy.com/?q=240sx+clutch |
#4 | |
#7 | |
Still, what are good clutches for a stock s14? I want to drift with it eventually but its also a daily, so, is there anything i should definetley avoid or is there anything youd recommend?
#10 | ||
![]() ![]() Feedback Score: 4 reviews
But a new clutch kit, try and find one that comes with the pilot bearing, bushing, release bearing. If you're trying to not have any down time get a new flywheel or buy a used one and have it resurfaced.
#13 | |
![]() Join Date: Jul 2005
AHhh ahahahahahaha hajhahahahahahahahah I finally get that picard picture |
#14 | |
Link And a how to clicky |
#16 |
Yes...it used to be cheaper to rebuild but our mass produced items allow for new instead of used...I have a local shop that does it and they do a great job...but they even advised if money is an issue get new...it depends on application...drifting get new...restoration eg your grandma's first car from 1930 get rebuilt cuz you won't find a new one
#17 |
Man w/ CTSV & a Car Seat
Question is whats done to the engine to help you decide how much of a clutch you'd need. No need to get some extreme heavy duty clutch if you're still on a KA. You can easily get an Exedy stage 1 or 2 and be more than enough for it.
#19 | ||
It's been awhile and my sense of sarcasm isn't what it use to be. There are shops that services/rebuilds clutch discs and can make it to custom spec if required. If one is local, and its a daily this is a viable option depending on the price. As mention no need to go all out, when your clutch reached it life limit.
#20 | |
2. Yes, it is technically possible to add new friction material to an old disc, but NO, it will not be easier or cheaper than just buying a (incredibly common/easily available) new clutch kit. |
#21 |
Im on the same boat. But i replaced mine with a regular autozone clutch and now after evrything is back in place my gears wont go in unless its off plus my clutch is way lower than it was before
