Old 12-01-2004, 07:01 AM   #1
Shad0w
Shad0w is an unknown quantity at this point
SSR Professor
Hi,
I`m going to import SSR Professor SP1 f 18x9 and r 18x10 for my s14a (tires f225/40/18 and r245/40/18) I have done the s15 conversion so the front fenders are little bit wider than stock (20mm). So what offset should I get ? Rear fenders are rolled and I could use sone negative camber. Looking for deep dish
Thanks
Shad0w is offline   Reply With Quote
Old 12-01-2004, 07:46 AM   #2
KoukiMonster
KoukiMonster's Avatar
KoukiMonster can only hope to improve
nothing above 20+ i can tell you that much
KoukiMonster is offline   Reply With Quote
Old 12-01-2004, 08:19 AM   #3
nlzmo400r
nlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nice
Send a message via AIM to nlzmo400r
why would you stretch a 245 on a 10inch rim? the 8.5s im getting sit well with 245s, and the 7.5s up front im putting 225s on, your rims are much bigger, id go with wider meat
'my drinking team has a racing problem'
[email protected] - gt32 .6bar
nlzmo400r is offline   Reply With Quote
Old 12-01-2004, 08:31 AM   #4
Doriftomodachi
Doriftomodachi is an unknown quantity at this point
type in ssr professor sp1 when you go to google to search
Doriftomodachi is offline   Reply With Quote
Old 12-01-2004, 09:12 AM   #5
Shad0w
I have searched with google, but haven`t found anything that would help me
The ones I have found have pulled rear fenders.
Old 12-01-2004, 11:15 AM   #6
Doriftomodachi
Ok lemme help you out. With 20mm overfenders in front 18x9 +3 (MD) should be flush and have an 84mm lip. 18x10 +24 (SL) for the rear will get you a 97mm lip and look pretty flush. If you wanna go a little more crazy go 18x10 +11 (SL) for a 110mm lip out back. You will probably have to pull the rears if you go this route. Good luck!
Old 12-03-2004, 10:04 AM   #7
wylin
wylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud ofwylin has much to be proud of
just find nitekids and tell him you want some imput. he has large lipped professors of that size.
2003 G35 sedan, 03 m45, 06 S2000
wylin is offline   Reply With Quote
Old 12-03-2004, 12:52 PM   #8
adey
adey's Avatar
adey is an unknown quantity at this point
Go all the way. Pull your fenders and squeeze some 18*9 18*10 0 offset all 'round. 215 front and 225 rear.
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 12-03-2004, 02:32 PM   #9
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
I concur. 18x9 +0 is easy to fit up front with 20mm overfenders. Pull the rears a little bit and run 18x10 +0 or +5. would look soooo hot.
RBS14 is offline   Reply With Quote
Old 12-03-2004, 06:32 PM   #10
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
and the wheels will weigh how much each?
wootwoot is offline   Reply With Quote
Old 12-03-2004, 07:16 PM   #11
SpoolinRB
SpoolinRB is an unknown quantity at this point
Not to hijack but couldn't i also do 18x9 with 0 offset on 20mm fenders on front with a s13 hatch?
SpoolinRB is offline   Reply With Quote
Old 12-04-2004, 12:31 AM   #12
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
This size has been talked abotu and used soo much.-10 to +10 on both the 9 and the 10, decide depending on camber. Pulling rears will most likely be required. S13 is similar.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 12-04-2004, 12:48 AM   #13
KA24DESOneThree
KA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfection
Let me agree with wootwoot and ask you one thing: have you considered what the effect of adding that much unsprung weight to your car will be? If you haven't, or if you don't care, then I'd seriously think about it. Jumping on the bandwagon can have its consequences. Look up the definition of "unsprung weigh" on google if you don't know what it is, and then weigh the pros and cons. In my book, the cons outweigh the pros. In yours, it might be vice versa.
/sermon
KA24DESOneThree is offline   Reply With Quote
Old 12-04-2004, 01:32 AM   #14
chmercer
chmercer's Avatar
in the front you could go 18x9 -25 or so with thoes overfenders and around 3 camber, i run 17x9 -1 with no trouble on s14 fenders with very mild pull
chmercer is offline   Reply With Quote
Old 12-04-2004, 03:01 PM   #15
RBS14
RBS14's Avatar
I can guarantee forged professors in that size aren't going to weigh half as much as 90% of other cast wheels half their width.
