Old 12-02-2004, 06:33 PM   #1
blitz180
blitz180 is making his/her stupidity well-knownblitz180 is making his/her stupidity well-knownblitz180 is making his/her stupidity well-knownblitz180 is making his/her stupidity well-known
Send a message via ICQ to blitz180 Send a message via AIM to blitz180
Brake Warning Light Comes on sometimes
Ok I know that is is a warning light as well and not just a Parking Brake Indicator, but if my fluid was low, or the pads were wearing, wouldn't my light stay on? Not come on sometimes and go off sometimes? Some other ideas? The brakes do not feel like they stick, accel is fine with no drag, and there is no apparent smell after driving.
Any Ideas? This came about after some parking lot drifting by the way.
blitz180 is offline   Reply With Quote
Old 12-02-2004, 06:43 PM   #2
projectRDM
projectRDM's Avatar
Low fluid will slosh around in the reservoir, tripping the light. Fill it back up.
FORMERLY R240NA
Old 12-03-2004, 08:11 PM   #3
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
low fluid made mine intermittent for a couple days before it stayed on for a long time.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 12-03-2004, 09:25 PM   #4
PinkPanther
PinkPanther's Avatar
PinkPanther is an unknown quantity at this point
Send a message via AIM to PinkPanther
KA
The only reason you have low brake fluid in your reservoir would be if: you forget to fill all the way after completely bleeding it, or it leaked out somewhere, meaning you need to inspect the lines asap.
I have the same problem-apparently it's quite common in these cars, because I have several friends w/ the same problem. It only happens to me during the winter(now) when it's rediculously cold. there are only two sensors that will set it off: the low brake fluid sensor mounted directly on the resivoir or the E-brake switch; which I think is the problem on my car.
PinkPanther is offline   Reply With Quote
Old 12-04-2004, 12:04 AM   #5
AKADriver
AKADriver's Avatar
Not just a leak, but extremely worn pads will also cause it, because all the brake fluid will be down in the calipers. That's the most likely problem.
Old 12-04-2004, 07:04 AM   #6
blitz180
I put on X-drilled rotors all the way around, hawk pads, and technafit lines from SPL on there. This was in July, and I've only been to auto-x once. I drive fairly aggressive on the streets but i'm not a "brake abuser." My pads don't look to worn from what I can see, but I haven't taken them off yet, it just looks like they are pretty thick still. I haven't checked for a leak as of recent, but they did not leak in the first week or 2 that i put them on because I checked them. Can anyone vouch for the life of hawk pads? Is it possible that a sensor could be bad? I'm putting the car away in a few weeks, and if i don't see anything apparently wrong, I'll wait until then to take everything off and give it a good look over.
Old 12-04-2004, 10:05 AM   #7
Andrew Bohan
my s13 leaked from where the mc bolted to the brake booster. i've seen a bunch of brake boosters with the black eaten away, which shows that it's not that uncommon for mc's to leak there.
