Old 07-15-2016, 08:23 PM   #1
Mofuhcka
Mofuhcka's Avatar
Mofuhcka is an unknown quantity at this point
Having SR Problems
SR is running weird, here is whats going on what I have already looked into:
Runs at 10.0 AFR
Replaced maf
TPS works
Coolant temp works
All spark plugs/packs are working
Injectors aren't leaking
O2 is replaced
No boost leaks
No old lines
Ecu is throwing code but won't let me read it
1500rpm idle
@hcr32love 400whp NEO R32 Sedan
Mofuhcka is offline   Reply With Quote
Old 07-15-2016, 09:11 PM   #2
David48
David48's Avatar
David48 is an unknown quantity at this point
Send a message via AIM to David48
How did you test for boost leaks? When is it running 10.0 AFR? At idle, cruising, or under load?
Also, did this just recently start happening? Or is this a swap you just installed and are trouble shooting?
David48 is offline   Reply With Quote
Old 07-16-2016, 06:45 AM   #3
Mofuhcka
Mofuhcka's Avatar
Idle and cruising. Under load goes lean. Sprayed all the couplers with starter fluid. When starter fluid goes in the system the idle drops
Old 07-16-2016, 06:53 AM   #4
David48
David48's Avatar
Do you have an adjustable fuel pressure regulator? Or if it's stock, have you tried another one? It's also worth opening the ECU to look for any burnt terminals or corrosion.
Old 07-16-2016, 07:41 AM   #5
Mofuhcka
Mofuhcka's Avatar
The FPR is working fine. Ill crack open the ecu
Old 07-16-2016, 01:58 PM   #6
ultimateirving
ultimateirving's Avatar
Try pressurizing the system and listening for air leaks
Z32 with lq4 swap
Old 07-17-2016, 09:27 AM   #7
jedi03
Try adjust iacv an make sure throttle closes aka throttle cable isn't stuck
