![]() Join Date: Sep 2012
93 240sx
Sad day.. so I think the time has come that I go separate ways from the 240. Alot has been done to it
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Engine: Blacktop Sr20det Brian crower 264 cams Brian crower Springs Brian crower retainers and clips Rocker arm stoppers Weisco forged pistons Forged eagle connecting rods Hks actuator Godspeed greedy style intake Godspeed exhaust manifold Unknown 750cc injectors Enthalapy tuned ecu Z32 maf New dual core aluminum radiator Dual electric fans Wiring specialties upper/lower harness Dual pipe down pipe Ebay 3" exhaust Clutch master 6 puck race clutch and flywheel Interior: S14 seats Somewhat fixed dash Circuit sport short throw shifter Triple gauge pod Boost gauge Water temp gauge Aem wide band Oil pressure gauge Fuel: Walboro 255l fuel pump Tomei fpr Exterior: Silvia front end (triple beams) Duraflex front bumper Duraflex rear bumper Duraflex sideskirts Xxr wheels Dmax tailights Brakes: Z32 4 pot front calipers and rotors Z32 2 pot rear calipers and rotors Stainless steel braided lines Suspension: Megan racing coil overs Godspeed front suspension Godspeed rear control arms Car currently doesn't run just have a few things to do to get the engine to start. Still have to have the rotors turned and brakes and clutch bled. Car started and ran fine just had a tapping noise in the head which I found out was the lobe hitting the rocker arm. I've take the lifters and bled them and haven't started it since. So a trailer will be needed to pick it up and take it home. Sent from my SM-G930P using Tapatalk |
Bleed brakes bleed clutch install the bov and run vacuum hose for it. Check clearance on exhaust cam to the lifters. And bleed radiator. I have gauges for it but they have to be installed. I had oiler ones in it and never got around to running the new wires for the new gauges.
