Old 12-07-2004, 09:37 PM   #1
L.D. 100
L.D. 100 is an unknown quantity at this point
what is gook?
I was reading the archived thread about flushing your engine using tranny fluid, 0w30 oil, and gook. I went to pep boys, checkers and autozone, and I cant seem to find this so called gook. When I asked for help finding it some old lady behind the counter said "that would be so wrong" I guess she was reffering to the name? either way she never heard of this product. so what is it/where do I buy it?
L.D. 100 is offline   Reply With Quote
Old 12-07-2004, 09:46 PM   #2
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
gunk?
gunk?
or, gunk?
http://bhworld.wordpress.com/
Old 12-07-2004, 09:57 PM   #3
L.D. 100
no not gunk, I know what that is. but the thread says gook? see... http://www.zilvia.net/f/showthread.php?t=16766 or was it misspelled?
Old 12-07-2004, 10:54 PM   #4
Teh Luckinator
Teh Luckinator's Avatar
Teh Luckinator is an unknown quantity at this point
The only "gook" I know is the derogatory term for asian.
Gook.
@goodluckleague
More than Lucky lives in stockton?
Teh Luckinator is offline   Reply With Quote
Old 12-07-2004, 10:58 PM   #5
trsilvias13
Gook.
gook is a derogatory term toward koreans from the vietnamese. from waht i know , korean call themselve gook in their own language, but from the vietnamese person in vietnamese it means sh*t.
that just to clarify what it means if no one gets it
Old 12-07-2004, 11:14 PM   #6
SimpleSexy180
its gunk...
SimpleSexy180 is offline   Reply With Quote
Old 12-07-2004, 11:41 PM   #7
XxJaPxOxNeEs23xX
XxJaPxOxNeEs23xX's Avatar
XxJaPxOxNeEs23xX is making a name for him/her selfXxJaPxOxNeEs23xX is making a name for him/her self
Send a message via AIM to XxJaPxOxNeEs23xX
koreans are called hangook not gook. cuz gook itself means soup i thnk.
XxJaPxOxNeEs23xX is offline   Reply With Quote
Old 12-08-2004, 02:10 AM   #8
idlafie
idlafie's Avatar
It was misspelled. What the thread is referring to is "Gunk Motor Flush"
It comes in a plastic bottle or metal can.
http://www.gunk.com/a_lineart2.asp?img=MF3.JPG
http://www.gunk.com/a_lineart2.asp?img=MF2.JPG
Gunk Motor Flush is a solvent which flushes out all the grime & sludge which builds up in your engine. Because it's a solvent, it acts like a detergent to clean out your oil passages and helps to free sticking valves and crud around your piston rings. It's great to use before an oil change because it helps to clean out your engine of all the crap thats in it. About the only problem is though, Gunk Motor Flush does such a good job that it might get rid of that exact same grime & sludge built up around your oil seals and may cause your engine to start developing leaks around those seals. Also, all that gunk & sludge that the Gunk Motor Flush loosened, could clog up the screen to your oil pump causing your engine to seize from lack of oil lubrication.
If you plan on using Gunk Motor Flush on your high mileage motor for the first time, it's best to drop the oil pan & clean out all the grime & sludge that the Gunk Motor Flush loosened & deposited in the oil pan. I've used this stuff for years on various cars I've owned thruout those years, haven't had any oil related problems on any of those motors in the time that I've owned them.
Anyhow, hope this helps...
ID
Old 12-08-2004, 02:44 AM   #9
-usmd-180sx
-usmd-180sx's Avatar
-usmd-180sx is making a name for him/her self-usmd-180sx is making a name for him/her self-usmd-180sx is making a name for him/her self
if im not mistaken.. white ppl call vietnamese AND koreans "gooks" to clarify.. but that is "white" ppl.. Also.. gook means "soup" in korean.. and "gook" itself isnt describing koreans.. like stated above.. its "hangook"
little clarification to all those less fortunate ppl out there that dont knoe the "real" facts.
my 02.
ps.. good info idlafie
-usmd-180sx is offline   Reply With Quote
Old 12-08-2004, 12:26 PM   #10
L.D. 100
alright thanks for the replies guys. especialy idlafie,very helpful. and no offense to the Asians out there, someone should edit the archive.
Old 12-08-2004, 04:19 PM   #11
dvdevo
dvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enough
ahahah you said gook.. hahaha..damn too funny.
maybe not as funny as the 'nig brake' upgrade thread.
dvdevo is offline   Reply With Quote
Old 12-08-2004, 05:38 PM   #12
vegita319
vegita319's Avatar
vegita319 is an unknown quantity at this point
Send a message via AIM to vegita319
that is funny, nice thread title. I was thinking o man, someone must have called him that when i saw it. Then i saw it was gunk. Lol. Glad it got cleared up.
vegita319 is offline   Reply With Quote
Old 12-08-2004, 06:17 PM   #13
Teh Luckinator
Goes into Autozone:
"Hi, can I get a gook?"
Haha.
@goodluckleague
Old 12-08-2004, 07:18 PM   #14
MidnightstarS13
MidnightstarS13's Avatar
MidnightstarS13 is an unknown quantity at this point
Send a message via AIM to MidnightstarS13
ID
This is half true. The other half is that Gunk Engine Flush is petroleum based which can burn your valve seals and crankseals which can be bad overtime. I've used it once and never again. Just an FYI.
MidnightstarS13 is offline   Reply With Quote
Old 12-09-2004, 02:44 AM   #15
idlafie
idlafie's Avatar
Yep..Gunk Engine Flush is definitely indeed mostly a petroleum based distillate, (about 88-92% additive...check the Material Safety Data Sheet see attached link: http://www.gunk.com/msds/MF3.PDF
However considering the high revolutions your motor runs at on a daily basis and normal wear & tear on your engine, Gunk Motor Flush burning out your valve seals & crank seals should be the least of your concerns. Gunk Motor Flush is not meant to be left in your engine as part of your oil change...It's meant only for use as a motor flush. It should only be used for about 5 minutes with the engine idling at normal RPM. It's purpose is mostly to wash out all the gunk & sludge that can build up in your oil passages from oil breakdown due to high temperatures. That gunk & sludge can buildup and restrict your oil flow to your oil pump. Insufficient oil flow can cause your motor to spin a bearing on the crankshaft resulting in you having to replace your motor. Using Gunk temporarily as a engine oil/motor flush will not affect the valve seals & crank seals as drastically as one may think. Clogged oil passages will!!
I've got over 135k miles on my motor, and have used Gunk Motor Flush over 38 times with each oil change, (I'm lazy...I average an oil change about every 3500 miles), & have not had any problems using it. To be fair, you can't judge a product on a one-time-use experience. You have to use it several times before you can come to an objective conclusion. If the product were THAT bad, consumer demand, (or lack thereof), would have had the product removed from the market YEARS ago!!
Considering my car/motor has over 155K miles, (I got the car used at 20K miles), I'm more concerned with the crank seals & valve seals failing from daily use/wear & tear than failing from using Gunk Motor Flush. Considering how I abuse my motor on my daily drives, I'm surprised my motor is still running strong. My oil pump or piston rings will probably fail way before my valve seals or crank seals do!!!
But that's my opinion......
ID
Old 12-09-2004, 05:06 AM   #16
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
lol i swear i didnt know if he was being serious or not...
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
