Old 11-04-2016, 10:19 PM   #1
nomoremrriceguy
nomoremrriceguy is an unknown quantity at this point
S14 1JZ swap dakota digital install
I saw the thread on the s13 writeup for the DD install. Has anyone installed the dakota digital box with the r154 transmission in the s14? Instructions are still unclear for me, thanks
nomoremrriceguy is offline   Reply With Quote
Old 11-04-2016, 10:27 PM   #2
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
for the speedo im assuming no tach?
Black240Ct is offline   Reply With Quote
Old 11-04-2016, 10:32 PM   #3
nomoremrriceguy
tach is working, speedo is not
Old 11-05-2016, 06:24 PM   #4
nomoremrriceguy
Anybody install one of these?
Old 11-05-2016, 09:05 PM   #5
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
I wrote the thread on using these with an s13, the whole process is the same for the s14. I even put all of the Toyota part numbers for the connectors and wiriing.
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 11-06-2016, 12:04 AM   #6
nomoremrriceguy
I saw that, most helpful thread ive seen so far. I just didnt see any specific pictures on wiring exactly, where do you wire it in the cluster? and is the speed sensor on the r154 accesible from removing the shifter trim?
Old 11-06-2016, 05:52 AM   #7
landins13
landins13's Avatar
No, it's fairly low on the side of the transmission, you have to get under the car. As for the wiring everything on the Dakota box will be new wiring (power and ground) with the exception of the signal going to the cluster, you just need to figure out what color the speed signal is for your car.
NO HANDS IN PANTS!!
Old 11-06-2016, 05:55 AM   #8
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
Which calibration method did you use? ^
corkscrew is offline   Reply With Quote
Old 11-06-2016, 08:40 AM   #9
nomoremrriceguy
so are you splicing power and ground from existing wires?
