Old 12-11-2004, 01:25 PM   #1
95 S14
95 S14's Avatar
95 S14 is an unknown quantity at this point
skyline brakes
I bought some skyline brakes for my 95 240sx se and when I got them I found that I needed a drum style e-brake in order for the e brake to work. Does anyone know if the drum stle ebrakes from a 92 300 zx will work?
95 S14 is offline   Reply With Quote
Old 12-11-2004, 01:27 PM   #2
projectRDM
projectRDM's Avatar
Exact same parts as the Z32, only the BNR33 and BNR34 use the larger rear rotors.
FORMERLY R240NA
Old 12-11-2004, 01:30 PM   #3
Ritz S14
Ritz S14's Avatar
You would also need the z32 ebrake cable. Not an easy install, but very doable.
Ritz S14 is offline   Reply With Quote
Old 12-12-2004, 03:34 PM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I cant remember now, but isnt there something you have to modify *cut* in the rear to make the Z rear brakes work?
Old 12-12-2004, 04:22 PM   #5
Ritz S14
Ritz S14's Avatar
Nope. The fronts you have to cut the dust shield though.
Old 12-12-2004, 11:00 PM   #6
Dousan_PG
Dousan_PG's Avatar
what the FUCK are you talking about?
the z32 install is VERY easy for the rears
the s14 takes more work then the s134, but not a lot, little fab nothing crazy thoug
wtf
you ever do it yourself on your car?!
its easy as pie.
Aaron
Pink GodziRa
Old 12-12-2004, 11:15 PM   #7
Ritz S14
Ritz S14's Avatar
Yeah I've done it, made a thread about it too. Well the the rear brake conversion itself is easy, just the e-brake was a bit difficult to me. Cause I tried to make my own way of making use of the z32 e-brake. But then I just defaulted to the "standard" way of doing it. All I need now is just to weld the s14 cable to the z32 cable.
http://www.zilvia.net/f/showthread.p...4&page=2&pp=30
Old 12-12-2004, 11:23 PM   #8
Dousan_PG
Dousan_PG's Avatar
you dont have to weld it
you can crimp them
if crimping can hold a marlin im sur eit wll hold your ebrake cables together hahahaha
im doing that with mine
cars finally up and running and legal so i can get a chance to fix it
edit: christ you paid a lot for your z conversion! OUCH!
Aaron
Pink GodziRa
Old 12-12-2004, 11:35 PM   #9
Ritz S14
Ritz S14's Avatar
Yeah, but I have a mig welder so why not =)
Rears 185 total with cable/pads/rotors/calipers.. front yeah I paid out the ass to piece it together. they're dirt cheap now.
Old 12-12-2004, 11:38 PM   #10
Dousan_PG
Dousan_PG's Avatar
ah cool
mm i c ic
no worries
oh for the record, my friend has R34 GTSt? on his s14 front and rears
bigger then z32
and its noticeably bigger
Aaron
Pink GodziRa
Old 12-12-2004, 11:39 PM   #11
Ritz S14
Ritz S14's Avatar
Rears on mine are R32s.. Don't know which trim, but TheSnail hooked up though.
