Old 12-14-2004, 05:17 AM   #1
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
s13 Idle fluctuation when i'm idling on idle.
When my car's warm, and I'm in neutral... sometimes the idle will jump up to 1500, then drop to 500-800, go up to 1500, then drop to 500-800. It'll keep doing this.
I think it could be several things-
Coolant temp sensor
Vacuum leak
Idle Air Control Valve
Atmospheric BOV???
Anyone can help me narrow it down?
Oh yeah, it's an S13 redtop.
95zilvia is offline   Reply With Quote
Old 12-14-2004, 05:45 AM   #2
S14DB
AFC #1
S14DB's Avatar
I would say coolant temp sensor. They tend to give wild swings when they go.
Old 12-14-2004, 09:54 AM   #3
nacstate
nacstate is an unknown quantity at this point
Mine does that when the fan kicks on, but I thought that was normal.
not so normal??
nacstate is offline   Reply With Quote
Old 12-14-2004, 12:19 PM   #4
kingsol
kingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enough
Send a message via AIM to kingsol
did you check your injectors? my idle did the same thing before i found out i needed to replace an o-ring.
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till.
-Emerson
kingsol is offline   Reply With Quote
Old 12-14-2004, 01:26 PM   #5
omen2853
omen2853's Avatar
omen2853 is an unknown quantity at this point
clean your AIV valve or just plain remove it. if that doesnt work, check for vacuum leaks, and go for the rest of those things you listed. first though, id check the AIV
omen2853 is offline   Reply With Quote
Old 12-14-2004, 03:03 PM   #6
95zilvia
So basically, everything is broken, haha.
Old 12-14-2004, 03:14 PM   #7
Dream240
Dream240's Avatar
not so normal??
It is normal for the idle to fluctuate when the cooling fans come on, same goes for when you turn on the A/C. But the revs should level off after a couple seconds.
Old 12-15-2004, 09:13 AM   #8
nacstate
ok thats what I thought, i'm good.
Old 12-15-2004, 01:45 PM   #9
aznpoopy
aznpoopy's Avatar
i had the same problem.
massive oil leak from front main seal was gunking up my alternator. cleaned it off and resealed.
also, cleaning the electrical grounds in the engine bay seems to have helped alot too.
jumping up to 1500 is normal; but i don't think it should take a bit for it to level off at regular idle. mine goes up to 1500 and right back to 800rpms.
