Old 12-30-2016, 06:32 PM   #1
C*bass
C*bass is an unknown quantity at this point
F/S- 1992 Toyota Aristo
Want to build another rx7, so this car has to go. Mostly testing the waters for now. Its a January 1992 build year so legal stateside now. It's pretty solid for a 25 year old car, just needs a coat of paint and some repairs to the aero.
Car was tuned/Dynoed this summer. Made 500whp at 1 bar before running out of turbo. Change the turbo, make more power.
HKS 272 cams
K1 Rods
CP Pistons
Titan Timing Belt tensioner
Titan Timing gears
Gates Racing Kevlar Timing belt
Ported Oil Pump
MR-S Shimless Lifter Buckets
Supertech Dual valve springs
Custom Intake Manifold
80mm Throttle Body
AEM 3.5bar Map sensor
Custom Twin Scroll Exhaust manifold
Comp 67mm Turbo
Twin Tial MVS Wastegates
Tial Bov
Sard Fuel Rail
1000cc Injectors
OEM Gaskets
4” front mount
AEM water/meth with custom reservoir
AEM 320lph fuel pump
AP engineering Powerfc and Commander
Aeromotive FPR
Fuel Lab 82802-1 Fuel Filter
-06 Return
-08 Feed
TRUST Oil filter relocation/thermostat
-10 Oil Lines to relocation and oil cooler
Setrab P/S Cooler
R154 swap
JZZ30 Ebrake
OS Giken TS2BD(freshly rebuilt this spring)
OS movement alteration kit
Driftmotion Billet Shift forks
Marlin Crawler Thrust washer
New bearings
New Synchros
One piece driveshaft
Diff/Driveshaft Rubber Isolater delete
LS400 Front brakes with Stoptech Slotted rotors
Wilwood Pedal Box Firewall mounted
New front upper control arms
New lower ball joints
Replaced front tension arm bushings with polyurethane
Rear suspension bushings swapped to polyurethane
PBM Coilovers
Factory Torsen Diff (can include open diff axle stubs if you plan to install aftermarket lsd)
Aluminum diff mounts
Aluminum Subframe mounts
Aluminum motor mounts
Solid Tranny mount
Battery Relocation
AEM UEGO
Defi Racer Oil pressure Gauge
Apexi Water Temp Gauge
Greddy Exhaust Temp Gauge
Greddy Boost Gauge
Sparco Pro2000 Drivers Seat
Recaro Passenger seat
Rays Revolvers 18x9 +24 front 18x10 +24 rear
Dunlop Direzza Z1 Star Specs front and rear
Kazz Sport Aero
What it needs;
Better driveshaft
Body/paint
Bigger Turbo
Needs Stereo
Legal stateside January 2017
Looking to get around $18500usd Delivered within reason (thinking any state west of Texas) if you want to deal with arranging everything yourself then make an offer. Would also be interested in partial trades for clean/titled FC3S rollers, preferably with no sunroof.
Car is located near Calgary, Alberta.
http://imgur.com/a/5IRVw
Hood's popped, more pictures in album.
C*bass is offline   Reply With Quote
Old 12-31-2016, 12:15 PM   #2
Sansone
Sansone is an unknown quantity at this point
This thing is super cool, glws
Life Ruiner
Sansone is offline   Reply With Quote
Old 01-13-2017, 09:00 PM   #3
C*bass
Thanks, your r32 isn't too bad either.
I should also add I have a pile of spare parts to go with it (axles, rack, a/c, coilovers)
Would also consider trades for sv1000, rc51 or maybe a vstrom.
