Old 02-20-2017, 12:08 PM   #1
Cee's S13
Cee's S13 is an unknown quantity at this point
s13 S14 FLCA's on S13
Just picked up some S14 FLCA's for S13. How much more negative camber do you think I'll get?
Cee's S13 is offline   Reply With Quote
Old 02-20-2017, 12:51 PM   #2
jared420sx
jared420sx's Avatar
jared420sx is on the path to ruinjared420sx is on the path to ruin
8 million degrees
jared420sx is offline   Reply With Quote
Old 02-20-2017, 12:53 PM   #3
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
man i miss the rep system
Old 02-20-2017, 01:26 PM   #4
RB25GUY
RB25GUY's Avatar
RB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to all
quick search on google
"It will increase track by 10mm on each side, which means that if you run the same amount of camber before and after installing the s14 FLCAs then you will have the same wheel fitment as a car with a 10mm lower offset and stock FLCAS. As far as actual wheel clearance is concerned, it will not be affected.
So it does not directly change the offset, but it will make the wheels fit the body of the car as if they were a lower offset."
Originally Posted by smellslikecurry View Post
Its not like you're putting a safc in a fucking Tesla.
RB25GUY is offline   Reply With Quote
Old 02-20-2017, 01:49 PM   #5
gaz_moose
gaz_moose is an unknown quantity at this point
depends how banana your chassis is,
its usually about 2 or 3 deg.
gaz_moose is offline   Reply With Quote
Old 02-20-2017, 03:36 PM   #6
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Fucking rigggght
Old 02-20-2017, 07:18 PM   #7
brndck
brndck's Avatar
This is not accurate. Since you're only moving the lower point, and not the upper point (top hat) you are in fact increasing camber AND track width.
Functionally, yeah you're probably safe just ballparking 8-10mm less clearance on your fitment, but technically it's not the same as just switching to a wheel with 10mm lower offset.
Splitting hairs.
Old 02-20-2017, 07:49 PM   #8
Standard
Standard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud ofStandard has much to be proud of
What a stupid thread haha
BRNDCK is right
Also, I think it's funny when people say "more camber"
More negative camber would be more accurate
Standard is offline   Reply With Quote
Old 03-17-2017, 07:34 AM   #9
Habibi240
Habibi240's Avatar
Habibi240 is an unknown quantity at this point
Will you need to change anything to run these other than the ball joints? Inner or outer tie rods maybe ?
Habibi240 is offline   Reply With Quote
Old 03-19-2017, 11:53 AM   #10
brndck
brndck's Avatar
to run s14 lca on s13, you only need to change the ball joint to match whatever knuckle you use (if you have s13 knucks, use s13 BJ, if you have s14 knucks, use s14 BJ).
you should definitely check your toe setting afterwards, since it will have changed
Old 03-19-2017, 01:06 PM   #11
bataangpinoy
bataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymore
You'll have so much camber it will be sick. Leave the toe setting and OE ball joints. Car will be MINTY.
/sarcasm
Originally Posted by GTR-Garage
Handling, power and style must be in harmony.
bataangpinoy is offline   Reply With Quote
