Old 02-22-2017, 09:03 PM   #1
rc1honda
rc1honda's Avatar
rc1honda is an unknown quantity at this point
Can I just swap crankshafts?
So I have a balanced and polished 91mm crankshaft sitting around.
Is it possible to just swap the 91mm shaft in for my stock 86mm?
I have a built SR with rods pistons bearings and ArP hardware. I want to swap in the 91mm shaft and make it a stroker motor.
Is it as simple as just installing the new shaft?
I've never dug into the bottom end before but it something I would like to learn as well.
rc1honda is offline   Reply With Quote
Old 02-23-2017, 07:14 AM   #2
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
If you add 5mm of stroke with a standard size rod and piston what do you think happens?
The answer is no, you'll need custom pistons designed for a 91mm stroke because they're shorter.
[email protected]
hanzbrady is offline   Reply With Quote
