06-04-2013, 04:47 PM | #61 |
Nah it's right on point. He's poor because he's building his dream S13... Especially with those fancy arms.
06-04-2013, 08:33 PM | #62 | |
Hopefully I can get some serious work done this weekend.
06-08-2013, 05:38 PM | #64 | |
06-08-2013, 06:02 PM | #67 |
Yep! Time to do some laundry.
My build http://zilvia.net/f/builds-builds-on...u-city-az.html Check out West Motors for all your automotive needs https://www.facebook.com/WestMotorsAz |
06-08-2013, 07:18 PM | #68 |
holy shit!!!
that setup pretty much allows you to make a u turn in the same lane that is insane keep it up!!
Two-Tone owner#011509-Lightly Modded |
06-08-2013, 08:04 PM | #69 |
That is stupid angle... I really dig the RC correction!
06-09-2013, 09:49 AM | #71 |
Thanks guys, I'm stoked on driving this thing soon.
From what I can measure, there is 70mm of correction in the hubs. I'm not sure where the 90-100mm comes from. There are so many adjustments on this kit it's crazy. I've pulled the camber plates almost all the way back to try and keep the strut in the PCD. This caused a lot of camber. I reduced it as much as I could at the knuckle, but these Kei-office coils are so long they hit the knuckle at the bottom. In this position, the tie rods are just a bit too long to let you run the control arms at their shortest setting. I have them at 16.5in bolt to ball joint center, but I think that's too far, as it has some toe out now for sure. I think I'll probably trim the sleeve on the tie rod a bit so I can run the LCA's shorter. There is more angle to be had for sure, the toe out needs to be fixed and there is still some ackerman in the steering. If I zero everything out I should get a few more degrees.
06-10-2013, 08:28 PM | #75 | |
The front fenders will go up and out quite a bit from where they are now, so I think I'll have outer clearance for either. We shall see!
06-10-2013, 09:38 PM | #76 | |
Trader Rating: (115)
Feedback Score: 115 reviews
06-19-2013, 09:52 AM | #77 |
so dope man!
Pics on here do no justice, to seeing your own car with that much angle i bet!...lol Cant wait to see it all ironed out and driving
cONtRol FReAkS |
06-19-2013, 11:53 AM | #78 |
Just found the suspension brand, do you mind me asking how much the front set up like that ran you?
Mighty fine build thread you have here sir, props! |
06-19-2013, 07:16 PM | #79 | ||
A lot I know, but nothing touches this as far as angle, roll center correction, and adjust-ability go. I could convert this to a purely road course set up in a day just by messing with the adjustments and drilling a hole for a sway bar. Hopefully I can get some work done on this weekend, I'm so close to having this running and driving! Cashflow is definitely limiting me at the moment.
06-20-2013, 07:52 PM | #81 |
Alright you got me hooked. This is pretty sweet. Some in bay pictures at full lock would be nice, to see if tubs are required. what size wheels do you have on there now?
06-21-2013, 07:06 AM | #82 | ||
I'll stick my 18x8.75+20's on this weekend (no tires unfortunately) and see how they fit as well.
06-22-2013, 08:08 PM | #83 |
So I got the toe a lot closer and test fitted the XXR's. they do limit my travel by about a quarter of an inch.
Actually mounted a fender to see what it would look like, fitment is going to be on point, maybe even too aggressive haha. Stock S14 wheels with 30mm spacer.
06-23-2013, 07:42 AM | #85 |
07-02-2013, 06:15 AM | #88 | |
Right now I have it where the strut axis is inside the PCD of the tower. As you can see this gives me quite a bit of caster. I wanted to start with it like this for two reasons. One, I wanted to see how it drove "inside the rules" and two, the rear isn't going to have much grip for a while so I don't think I'm going to be able to take advantage of the greater front grip from a big contact patch.
07-03-2013, 05:52 AM | #89 |
I finally got all four wheels on. My budget SUCKS for the next few weeks, so progress is going to be slow for a bit here
07-06-2013, 01:52 PM | #90 |
Apparently -8* (reduced from above pic) is the least camber I can run at the moment, and my shock axis isn't quite inside the PCD of the strut tower. If I had shorter coilovers I could run less, but at the expense of more positive camber at lock. Hmmm, not sure if I'm going to say screw it and move the axis outside the PCD, or leave it like it is and wait till I get shorter coilovers....
Before: \
