Old 07-24-2017, 08:19 PM   #1
Lpn26
Lpn26 is an unknown quantity at this point
Clutch won't engage
I'm having issue with my clutch. I recently upgrade to a stage 2 bit now my clutch won't engage. I have bleed it a few time and still nothing . I have removed the damper box and ran the clutch li e straight to the slave cylinder and nothing. I would appreciate any suggestion. Thanks
Lpn26 is offline   Reply With Quote
Old 07-25-2017, 11:57 AM   #2
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
have you confirmed the slave cylinder piston is extending AND retracting when you push the pedal down?
The Game
you lose haha
kyral is offline   Reply With Quote
Old 07-25-2017, 01:55 PM   #3
Jefro240
Jefro240 will become famous soon enoughJefro240 will become famous soon enoughJefro240 will become famous soon enoughJefro240 will become famous soon enoughJefro240 will become famous soon enough
Can you hear the release bearing when you push the clutch in?
Fork or Pivot may not be engaged properly etc so when you do push the clutch pedal in, it is not pushing the release bearing into the pressure plate to release the clutch.
Otherwise, as Kyral mentioned. Slave cylinder... Because if you are able to bleed it properly the MC should be fine.
| 92 S13 Hatch | 92 S13 Coupe | 95 S14.5 |
Jefro240 is offline   Reply With Quote
Old 07-25-2017, 03:53 PM   #4
Lpn26
Yes the piston is moving in and out I replace both master cyclinder and slave. I'm not sure I will check tomorrow. But if is not making noise what does the mean. Will i have to replace the the bearing?
Old 07-27-2017, 12:11 AM   #5
Lpn26
I can hear the release bearing when the clutch is engage. But it still won't let me put it in gear
Old 07-27-2017, 02:55 AM   #6
Dirk Jan
Dirk Jan's Avatar
Dirk Jan is a glorious beacon of lightDirk Jan is a glorious beacon of lightDirk Jan is a glorious beacon of lightDirk Jan is a glorious beacon of lightDirk Jan is a glorious beacon of lightDirk Jan is a glorious beacon of lightDirk Jan is a glorious beacon of lightDirk Jan is a glorious beacon of lightDirk Jan is a glorious beacon of lightDirk Jan is a glorious beacon of lightDirk Jan is a glorious beacon of light
So is your clutch not engaging, or not DISengaging? A clutch should always be engaged, even if your hydraulic clutch system doesn't work at all. So bleeding will never help it engage. Did you mount the clutch disc upside down?
@dedirkjan
Dirk Jan is offline   Reply With Quote
Old 07-27-2017, 07:53 AM   #7
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
with the engine OFF, can you shift through the gears?
Old 07-27-2017, 10:27 AM   #8
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
Clutch Lock out. Everything may be moving but the clutch disc is not separating from the flywheel. If you can put the car in gear when the engine off but not when its running I can almost guarantee thats the problem.
I had the same issue with my R154 not long ago and the clutch disc had seized against the flyheel. Pedal was fine, slave cylinder was fine, when I looked at the clutch through the inspection hole everything appeared to be fine.
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 07-27-2017, 04:01 PM   #9
Lpn26
The clutch is not engaging when the car is on. I don't think I mounted the clutch upside down, bu5 I could be wrong
Old 07-27-2017, 04:04 PM   #10
Lpn26
How did u fix it?
I can enter the gears when the car is off no problems but when I turn it on and try to go into first it won't let The clutch p3dal has no pressure once I turn the car on
Old 07-27-2017, 07:31 PM   #11
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
The clutch pedal pressure has nothing to do at all with the engine running or not running.
However, the fact that you say that it does indicates a major mechanical issue. Sounds like the best approach is to drop the transmission and take a look.
Ilya is offline   Reply With Quote
Old 07-27-2017, 09:15 PM   #12
Lpn26
I will drop the granny Saturday and see what going on.
Old 08-23-2017, 04:47 AM   #13
Dirk Jan
Dirk Jan's Avatar
So did you end up dropping your granny? Did she manage to get back up on her own?
@dedirkjan
Old 08-23-2017, 03:55 PM   #14
Lpn26
Lol. No I did not have to drop her. It turn out to be the clutch hard line it was not sealing right. She now walking fine.
Old 08-23-2017, 03:56 PM   #15
Lpn26
Thank you to every one who help I appreciate all the help
