Old 12-27-2004, 06:03 PM   #1
ALTRNTV
SR Electrical oil pressure gauge
Me and my friends are going to install an electrical oil pressure gauge on his SR. The oil pressure sender we have is size 1/8-27 NPT.
What adaptors and fittings would we need to make if fit on the SR without the oil pressure light going on.
Thanks
ALTRNTV is offline   Reply With Quote
Old 12-27-2004, 06:10 PM   #2
projectRDM
projectRDM's Avatar
The OE OPS doesn't trigger if it's unplugged. Remove it and throw it away.
FORMERLY R240NA
Old 12-27-2004, 06:12 PM   #3
ALTRNTV
Oh ok, thanks. So what fittings and adaptors will we need to install it.
Old 12-27-2004, 08:26 PM   #4
dnomyar
dnomyar's Avatar
dnomyar is an unknown quantity at this point
you'll need an adapter that goes from 1/8 NPT to 1/8 BSPT. i believe autometer makes one.
dnomyar is offline   Reply With Quote
Old 12-27-2004, 08:30 PM   #5
Dousan_PG
Dousan_PG's Avatar
www.splparts.com has a bunch of various stuff too
check it out
Aaron
Pink GodziRa
Old 12-27-2004, 08:32 PM   #6
SirWarrior
SirWarrior is an unknown quantity at this point
difference between the two is that NPT is 27 turns per inch and BSPT is 28.
you could also get a non US spec sender like Greddy or some other JDM one, those just screw in w.o any mods as they are already BSPT
92 FastBack - Project
98 SE - Daily Driver
SirWarrior is offline   Reply With Quote
Old 12-27-2004, 08:34 PM   #7
ALTRNTV
So all I need is a 1/8 NPT to 1/8 BSPT adaptor, and just plug and play? And will my oil pressure light really stay off? I don't like red lights lighting up on my dash.
Old 12-27-2004, 08:43 PM   #8
Dousan_PG
Dousan_PG's Avatar
unplug it off the dash haha
wont need it anymore anyways
Aaron
Pink GodziRa
Old 12-27-2004, 09:46 PM   #9
ALTRNTV
LOL... well, that's true
Again, so all I need is a 1/8 NPT to 1/8 BSPT adaptor, and just plug and play? And will my oil pressure light really stay off? I don't like red lights lighting up on my dash.
And what's a normal reading for an SR? At idle, start-up, and once its warmed up?
Old 12-27-2004, 09:49 PM   #10
Dousan_PG
Dousan_PG's Avatar
my pressure metric
is like at 6-7ish on startup
at idle and warm up around the same as what the RPM is
i forget the measurement, just know what is good and what is bad. hehe
bad-when the gauge is beeping nonstop (when im moving, not at traffic light)
Aaron
Pink GodziRa
Old 12-27-2004, 10:24 PM   #11
mr_240sx
mr_240sx's Avatar
your oil pressure gauge beeps at you? what type of gauge is it?
mr_240sx is offline   Reply With Quote
Old 12-27-2004, 10:29 PM   #12
Dousan_PG
Dousan_PG's Avatar
defi link sys
but waiting for my BF to get here (backordered)
its annoying
it also sucks to have BF boost and temp and link pressure.
Aaron
Pink GodziRa
Old 12-27-2004, 10:32 PM   #13
2pac owns a 240w/sr20det
2pac owns a 240w/sr20det is an unknown quantity at this point
Damn homie, dat ish looks thuggish-bombbbbbay
2pac owns a 240w/sr20det is offline   Reply With Quote
Old 12-28-2004, 09:00 AM   #14
projectRDM
projectRDM's Avatar
The light will not trip unless it sees 8psi or lower. Unplugged, there's no signal. Period.
FORMERLY R240NA
