Old 11-04-2017, 09:54 PM   #1
1jzsilcoupe
1jzsilcoupe is an unknown quantity at this point
C33 Rb25 swap
Hello all, I’m about to do a Rb25 swap on my 91 c33 laurel. I’m posting this in hopes for information on the swap.
Alright, details of the car now:
Rb20e
Automatic
What’s going in the car:
RB25det series 2
Rb25 transmission
Needed Information:
So when I bought this swap, it came with s13 engine mounts and transmission crossmember/Mount and a 1 piece steel driveshaft for Rb25 tranny in a s13.
I need to know if those s13 mounts will work? I know for my motor mounts, I can use my stock rb20e mount but for tranny crossmember/mount, do I use the stock c33 auto mount? Can someone shed some light on which mounts?
What about the driveshaft? Will that work? I think it’ll need to be lengthened but I’m not sure.
Also, will the stock Rb25 s2 engine harness plug straight into the laurel or do I need to do some wiring or get a harness?
Thank you all and I look forward to getting some solid info spread out.
1jzsilcoupe is offline   Reply With Quote
Old 11-05-2017, 08:31 AM   #2
Feast Japan
Feast Japan's Avatar
Feast Japan is an unknown quantity at this point
You will keep the RB front member and engine mounts ( I would upgrade to Nismo) and need manual R32 trans mount. Keep that shaft and have it modified to fit, front yoke I think for the 71C RB trans.
Wiring relays I think diff plugs inside car.
Feast Japan is offline   Reply With Quote
Old 11-05-2017, 04:15 PM   #3
1jzsilcoupe
Wow that is some beautiful information. Thank you very much! Does anyone have anything to add?
Old 11-05-2017, 04:39 PM   #4
1jzsilcoupe
Also, while we are at it, let’s see if we can shed some light on a manual swap in a c33 laurel. As far as the clutch pedal goes, can I use a lhd s13 clutch pedal assembly? Or do I need to use a r32 or Rhd s13 clutch pedal assembly? Thank you all!
