Old 02-06-2018, 01:07 PM   #1
Creolex
Creolex is an unknown quantity at this point
1995 240sx Gas Gauge Not Working
Fuel pump fuse kept blowing so I changed the fuel pump. The fuse issue is resolved but now the gas gauge is not working. NOTE: Before changing the fuel pump I noticed that it was not attached to the bracket. I attached the new pump to the bracket. It was working fine before I changed out the pumps which makes me believe that it may not be a bad sending unit and perhaps something that I did or did not do. Please advise.
Creolex is offline   Reply With Quote
Old 02-11-2018, 05:48 AM   #2
Gearhead9992
Gearhead9992 is a well-known jackass
When you pulled out the bracket for the pump did you pull everything else out
Gearhead9992 is offline   Reply With Quote
Old 02-12-2018, 01:57 PM   #3
oLemurs
oLemurs's Avatar
oLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura aboutoLemurs has a spectacular aura about
see if your floater detatched, if not move the rod around and see if it moves on the cluster
oLemurs is offline   Reply With Quote
Old 02-12-2018, 02:04 PM   #4
Gearhead9992
S14s don't have rods they have a big tube that sits on a bracket in the tank you will have to pull everything out and split the tube and check maybe clean the contacts
fuel pump
