is it possible to burn out the starter
what im saying is when i tried to start my car after it sitting for a while it wont even turn over, i have everything bypassed so i push a button and it starts so essentially when i flip the starter signal wire it will turn on even without a key in the ignition but heres where i possibly messed up. i put a screw behind my switch panel to hold it in but im thinking the switch possibly jumped the two connectors together and eventually burnt it out. i did see some weird smoke coming from near the intake manifold and im just wondering what would happen if i were to just hold down the starter for about a minute or two.
![]() Join Date: Jan 2010
yes. it is possible to burn out a starter.
yes. it is not good for your to crank the starter for 1-2 minutes. it can burn it out or shorten the life span of it. |
![]() Join Date: Jan 2012
you would hear it, its very loud. if you were to engage the starter at above like 5000 rpm i think the starter wheel would break off.
Jump the starter to see if it is your wiring or the starter itself |
that's the signal wire! lol I like reading through these, some people have great comments! it can come off if its not tight...I usually take some pliers and squeeze it tight to ensure it doesn't come off
it was definately just the ground that needed to be tightened on by a bolt
