Old 03-06-2018, 10:40 AM   #1
FTMFW
FTMFW's Avatar
FTMFW is just really niceFTMFW is just really niceFTMFW is just really niceFTMFW is just really niceFTMFW is just really niceFTMFW is just really niceFTMFW is just really niceFTMFW is just really nice
s13 running rich whyy
redtop sr20
so I tuned my car with safc the ecu is also tuned for the turbo and the injectors
everythime they tune it its good then starts running pig rich again changed the sock on the fuel pump still same anyone know whats going on
running gt2871r 740cc injectors ecu tuned for gt2871r and the injectors got a z32 maf and using SAFC2 please helpppppp
FTMFW is offline   Reply With Quote
Old 03-06-2018, 11:18 AM   #2
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
If you KNOW the ecu is tuned for the z32 maf and 740cc's, take off the safc and check afr's to start from there. If you're still running rich, then start checking for mechanical issues(Boost leaks, leaky injectors, etc).
di-devol is offline   Reply With Quote
Old 03-06-2018, 11:23 AM   #3
eagleeyes221
eagleeyes221 is an unknown quantity at this point
can you add anymore information as to whats going on?. you said you tuned the car yourself? was there anything you changed recently with the setup? was the car running good without the safc? without knowing anything thats going on id say start checking your sensor parameters and make sure that you are getting all of the proper readouts for them. i would also double and then triple check your tune. I had the same problem recently where my tune was off on my ls1. The motor was drowning itself in fuel because the tune thought it was getting ALOT more air than it really was.
eagleeyes221 is offline   Reply With Quote
Old 03-06-2018, 11:49 AM   #4
apex128
apex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enough
How rich are we talking? Do you have a wideband? Is the car stalling? Is this at idle only? We need more info if you want help.
apex128 is offline   Reply With Quote
Old 03-06-2018, 01:37 PM   #5
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Hoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really nice
Feedback Score: 25 reviews
Throw the safc in the trash and get a real tuning solution.
Hoffman5982 is offline   Reply With Quote
Old 03-06-2018, 03:14 PM   #6
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Your problem is compounded by the lack of information you presented.
What ecu do you have? You mention it's tuned for the injectors and the turbo, what about the MAF?
Why did you add an SAFC?
What settings are you using for the MAF in/out in the SAFC? For z32 I believe it's 2 in 6 out but that's on a KA24DE.
Old 03-08-2018, 11:44 PM   #7
FTMFW
FTMFW's Avatar
the safc im using to tune z32 maf
ecu is only tuned for turbo and injectors
problem im having is its breaking up under load aka boost
anytime full throttle just breaks up real bad
i had it dyno tuned by evolved tuning ran good a day and back to breaking up
Old 03-08-2018, 11:46 PM   #8
FTMFW
FTMFW's Avatar
ive checked timing changed and gapped plugs .028 changed injector O rings
Old 03-09-2018, 06:18 AM   #9
apex128
I think you might have a boost leak. Is your maf setup for blow through? That would explain the rich condition.
Sent from my 831C using Tapatalk
Old 03-09-2018, 10:52 AM   #10
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
What ECU is it? If you're building your set up for a budget, why not get an ECU that is set up for your MAF? Like an enthalpy, nistune or something?
Old 03-09-2018, 10:53 AM   #11
FTMFW
FTMFW's Avatar
Stock ecu tuned by jwt I believe I'll check again when I go to the car but it's tuned for the injectors and turbo
Sent from my SM-G930T using Tapatalk
Old 03-09-2018, 03:34 PM   #12
FTMFW
FTMFW's Avatar
so it runs perfect when i set to 4in 5out but a z32 maf should be 2 in any ideas?
Old 03-09-2018, 04:20 PM   #13
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
You're still not providing enough information.
What SR do you have? What ECU are you running?
Old 03-09-2018, 04:30 PM   #14
FTMFW
FTMFW's Avatar
Redtop sr stock chipped ecu
