Old 05-16-2018, 03:15 PM   #1
dcraine
dcraine is an unknown quantity at this point
Fully Built Sr20det Partout :: New Parts Updated!
Well the time has come, I recently got a killer deal on a 2jzgte so time to part ways with all of my Sr stuff. This motor only has 2,000 miles on it! Absolutely nothing wrong with it, pulled great, broke in properly and will take whatever you throw at it. I have most of the receipts for the parts and original boxes, weights of forged stuff.. ext.
Someone come buy this to fund my 2j build!
Will travel up to two hours to meet someone as long as gas money is involved.
Built Sr20det w/ 5 speed trans.
Stock bore
8:5:1 Compression
Je Pistons
Manley Rods
Acl Race Bearings
Arp Headstuds/Hardware throughout
Tomei Headgasket
New Valve Seals and Valve Job
Isr Oversized oil pan
Isr Gasket Kit
Isr lightweight pulleys
Oem waterpump/Thermostat
New timing kit
New dipstick tube
Stock fuel rail 370cc
Stock mani w/ stock t25
Xtd Stage 3 Clutch and Lightweight Flywheel
Circuit Sports shorthrow shifter
Exedy Slave
Tf valve cover nuts
Ecu
Cody Ace bracket for cold AC!
[IMG][/IMG]
[IMG][/IMG]
[IMG] [/IMG]
[IMG] [/IMG]
[IMG][/IMG]
[IMG] [/IMG]
Will Sell full setup/swap for $3500
Built Sr20det
Trasmission
Intercooler Kit
Radiator w/ Fans
Driveshaft
Wiring Specialties Pro Harness
Walbro 255
Or just Built Sr/Tranny for $3000
Also have a good amount of random parts.
Tomei PonCams 256/256 - Only 3,000 miles, Will include new timing chain gears aswell.
$150
Circuit Sport Rocker Arm Stoppers
$25
Oem Master Cylinder
$25
Oem Sr fuel rail with 370cc injectors
$50
[IMG] [/IMG]
[IMG][/IMG]
Oem Sr20det Intake Manifold with new gaskets and iavc.
$150
Oem Sr20det water necks
$25
Oem Sr20det Iavc
$35
Oem Sr20det Maf's
$70
[IMG][/IMG]
Oem Sr20det flywheel and pressure plates
$50 for one set
[IMG][/IMG]
New Isis z32 Maf and New Pigtail
$75
4x Oem Coilpacks
$75
Oem sr20det fuel rail without injectors
$20
Sr20det e6 ecu, ive ran this ecu on both my red and blacktop and it worked perfect.
$100
[IMG][/IMG]
Oem sr20det stock rods and pistons, nothing wrong with them besides some surface rust. Would be good for a budget build. All rings still on them, Went stock bore forged.
$50
[IMG][/IMG]
Sr20det Head, bottom end spun a rod. Nothing wrong with the head it had the Tomei Pon Cams in it and will not come with them unless you buy both.
$200
[IMG][/IMG]
Spare Sr20 Transmission
$200
[IMG][/IMG]
Bare sr20det valve cover and gasket
$75
[IMG][/IMG]
Cx racing brand new top mount t3/t4 manifold for sr20det. Was reinforced heavily and pressure tested by Borla Performance.
$200
[IMG] [/IMG]
New Garrett Gt2871r .86
$Pending
Sard Top Feed fuel rail
$sold
1000cc Injector Dynamics Injectors
$sold
Spare Cas
$75
S14 black glove box
$50
S14 black outer cluster trim piece
$20
Innovate Lc-2 Wideband with new O2 sensor
$sold
dcraine is offline   Reply With Quote
Old 05-16-2018, 04:58 PM   #2
Samiata
Samiata is an unknown quantity at this point
interested in turbo lmk if other guy doesn't go through
Samiata is offline   Reply With Quote
Old 05-16-2018, 05:15 PM   #3
roninwon
roninwon's Avatar
roninwon is an unknown quantity at this point
Send a message via MSN to roninwon Send a message via Yahoo to roninwon
Coil packs, cas?
roninwon is offline   Reply With Quote
Old 05-16-2018, 05:34 PM   #4
dcraine
Originally Posted by roninwon View Post
Coil packs, cas?
Yes sir, have a spare cas and i believe two sets of coil packs.
Old 05-16-2018, 05:35 PM   #5
dcraine
Alright man, Ill keep you updated should be going through tonight.
Old 05-16-2018, 07:54 PM   #6
roninwon
roninwon's Avatar
How much shipped to 13603?
Old 05-16-2018, 07:55 PM   #7
nisileighty
nisileighty's Avatar
nisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of light
Are they s13 valve covers?
Edit: Nvm, pics just loaded. I’ll take one, text me at 206 566 9749. Thanks.
nisileighty is offline   Reply With Quote
Old 05-16-2018, 09:57 PM   #8
borka
borka is an unknown quantity at this point
PM'd about ID1000 and Innovate WB
borka is offline   Reply With Quote
Old 05-17-2018, 07:47 AM   #9
boya1989
boya1989 is an unknown quantity at this point
I need that intake that goes off the turbo
boya1989 is offline   Reply With Quote
Old 05-17-2018, 08:02 AM   #10
dcraine
Not parting that out yet man
Old 05-17-2018, 08:04 AM   #11
djtoonjr
djtoonjr is an unknown quantity at this point
A/c
How much for Cody Aces , a/c bracket? U got all the hardware? u got all the A?C stuff too? compressor, lines off compressor?
djtoonjr is offline   Reply With Quote
Old 05-17-2018, 08:09 AM   #12
Kviper52
Kviper52's Avatar
Kviper52 is an unknown quantity at this point
LC-2 Still availible?
1991 240sx Coupe-Drift Car
1995 240sx LN1-Show Car
1993 Skyline ECR33-Street Car
1997 240sx -Wife Car
My Cars and Their story:
http://zilvia.net/f/showthread.php?t=657376
Kviper52 is offline   Reply With Quote
Old 05-17-2018, 08:18 AM   #13
dcraine
$50 for the Cody ace bracket and I do have an ac compressor attached I’d let the whole setup go for $150. It worked perfect on my car, but I’m keeping the ac lines as im going to have ac on my 2j build.
Old 05-17-2018, 08:19 AM   #14
dcraine
Yes sir I sure do
Old 05-17-2018, 08:24 AM   #15
borka
Originally Posted by dcraine View Post
Yes sir I sure do
i want the ID1000 and LC2. i am still waiting for you to reply to my PM.
Old 05-17-2018, 01:16 PM   #16
djtoonjr
What compressor is on it? can u PM pics of it, to verify it'll clear my manifold based on hose position? thanks
Old 05-17-2018, 01:23 PM   #17
nisileighty
Bump for great seller. Fast shipping.
Old 05-17-2018, 02:03 PM   #18
joaquin714
joaquin714 is an unknown quantity at this point
Thanks for the Cody ace bracket! Quick communication and prompt shipping
Bump
joaquin714 is offline   Reply With Quote
Old 05-17-2018, 06:22 PM   #19
Keegster
Keegster's Avatar
Keegster will become famous soon enoughKeegster will become famous soon enoughKeegster will become famous soon enoughKeegster will become famous soon enoughKeegster will become famous soon enough
Interested in compressor if its a dual cam s13, and coil pack harness
Keegster is offline   Reply With Quote
Old 05-17-2018, 07:12 PM   #20
lewisfk
lewisfk's Avatar
lewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond repute
What's up with ecu. I.e. tune
lewisfk is offline   Reply With Quote
Old 05-17-2018, 07:58 PM   #21
dcraine
Stock Ecu stock tune
Old 05-20-2018, 05:53 PM   #22
dcraine
Bump it up let’s get this stuff sold!
