![]() Join Date: Jan 2009
Trader Rating: (25)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 25 reviews
RB25 Flywheel on KA24DE-Improperly balanced?
So I recently blew my ka up, again. The same day it went I was told the rb25 flywheel isn't balanced correctly for a ka and will cause it to destroy bearings. This is the first I've heard of this and it has me a little paranoid. My ka didn't go in a normal manner. Rod bearing number 3 was absolutely destroyed but didn't spin and no visible damage was done to the crank. All tolerances were spot on when it was assembled. I'm throwing my turbo setup on another long block so I want to figure out if I need to get rid of this setup or not.
Thanks!
![]() Join Date: Sep 2014
![]() Feedback Score: 13 reviews
Not sure if it helps or not but I also run the same flywheel on my ka and have for 10k miles and never heard of such a thing. Matched with an ATC clutch, no problems here.
Sent from mTalk |
![]() Join Date: Mar 2012
imo if it was an imblance issue it would affect no1 and no5 main bearings
as it would pivot ever so slightly round the center main & thrusts it wouldn't affect one big end bearing only,that is another issue possibly starved oil feed,con rod out of round (distorted cap?), bearing layers lifted etc three bearing mains 4 cyl engines suffer crank flex and take out the center main the center main will fail first or the crank snaps in two before the BE bearings fail |
![]() Join Date: Nov 2005
Out of curiosity, what were your main bearing clearances? When did it start knocking and what do you use the car for? Do you have a well-baffled oil pan?
A flywheel has very little to do with crank balance, which is part of the reason why there are so many weight options available.
#9 | |
Trader Rating: (25)
I figured. I don't think it was oil starvation because I did about 8 more laps of steady redline after the sound started and there isn't a single mark on that journal of the crank. I haven't taken the head off to see if there was detonation, although the car ran perfectly fine and I never heard any pinging.
Trader Rating: (25)
I really didn't think there was any truth to this. I just wanted to be 100% sure because if so I could have sold my current setup. This saves me time and money. Thanks everyone!
#12 | |
Also double check the big end dimensions of those eagles, they're notorious for being inconsistent/out of round and needing a resize.
#13 | |
Trader Rating: (25)
For reference, I'm only running ~11psi on a 2871 which yielded 290whp and I lowered the rev limiter down to 6850
#14 |
Trader Rating: (25)
I'm running an RB25 XTD 14lb flywheel(I know, but my ka xtd lasted 4 years of abuse with zero issue) and an RB25 Competition stage 3 clutch set
#15 |
![]() Join Date: Jul 2005
I do not think of a flywheel as a component of natural frequency damping.
It can be out of balance but that should be obvious (vibrations) If it wasn't damping natural (resonant) frequencies of the engine in question then that is a whole other story (you would not feel that happen, and it will show as 'perfect balance' with respect to mass) If you modify the inside of the engine and the natural frequencies change, then something needs to be done about new emerging natural frequencies. Typically people throw a fluidamper and go. I presume that you have a fluidamper and are not trying to utilize a stock damper with aftermarket internals. -.- also what was said about using tight (factory) clearances with heavy weight oils is correct (=failure) |
#16 |
Funny story. I bought a comp clutch for a KA that I bought with a bad clutch. After I installed it I wondered why the car had a shit top end and hated to rev. Later I learned that the pressure plate was drilled off-center. I’d imagine with solid mounts it would have been much more obvious.
