Old 02-07-2019, 10:59 AM   #1
rswails
rswails is an unknown quantity at this point
FS 1996 240sx 2jz s14 kouki
*SOLD*
12k FIRM
Alas I must part with my CLEAN, 2jz swapped 1996 Nissan 240sx, with 1997 Kouki front end conversion.
102,500 original miles on the chassis. Clean title. After getting this running I only drove it probably 2,000 miles.
Video link of it running: https://photos.app.goo.gl/JX1XrAubEQNPaoP57 ( it does hit 10psi now, even though it didn't back when I took this vid )
PICS: https://www.dropbox.com/sh/mthug7td2...yvDIQy2ca?dl=0
Aristo 2jzgte VVTI swapped engine running stock twins ( from Canada, they estimated about 40k miles was on the engine at the time I installed it )
Engine runs great, idles great.
Supra Mark IV NA W58 transmission smooth shifting. This is not the weak W58's this is the strongest W58, good for 400-450HP.
Engine totally stock except boost controller installed to avoid boost cut.
RPS Max street clutch kit and flywheel resurfaced ( good to 450hp, and engages super smooth )
Nearly all seals/hoses replaced. Bought full OEM complete gasket kit.
No leaks.
Xcessive swap kit
Heat works
Power steering works
A/C compressor in place, but not lines and condenser are not hooked up.
Brakes are great, no warped rotors
Power windows/ locks all work fine.
1997 altima fans install, wired for only one fan on hispeed right now and it cools great, never overheated. THESE BLOW HARD
CXRacing 3" Intake Kit For 2JZ-GTE Motor with Stock Turbo S13 S14 S15 Swap
I welded the aluminum hot pipe myself.
KOYO aluminum radiator
Replaced OEM water pump
Replaced OEM TSTAT
Replaced Timing belt with Gates Blue racing timing belt AND tensioner
Replaced front main seal and rear main seal
Replaced spark plugs with NGK bkr6eix-11
Replaced oil pan gasket/RTV
Replaced fuel filter
Compression tested: 174,172,176,175,176,177
AEM TruBoost A piller mounted
Apexi turbo timer
AEM uego wideband A piller mounted
Dakota Digital included
EGT gauge, probe installed, gauge is not installed in dash
Walbro 255 fuel pump
Greddy front mount intercooler
Tial BOV ( not installed )
custom exhaust no cat, Magna Flo muffler sounds great, wideband installed and working, and OEM O2 sensor installed and working
Nearly new Cusco RS LSD ( not installed but will include with purchase )
steel custom driveshaft from the awesome people at The Driveshaft Shop
Code alarm brand ca-1550 alarm system
Suspension:
Megan racing springs
KYB GR2 suspension
Godspeed adjustable toe arms
new sikky sway bar, not installed
Exterior:
Kouki side skirts
Black paint in great condition. Original OEM paint was red
17x9 rota p45r bronze wheels. 245 40 r17 rear 235 45 r17
Nitto Invo tires. Fronts have lots of tread left
usdm font lip
8k HIDs
LED license plate lights
Interior:
The interior is in good shape. There is the infamous crack on the dash, but besides that there's nothing else wrong
Blue LED dome light
white LED trunk light
Issues:
Won't boost over 10psi even with EBC set to 18psi. I believe the stock ECU is causing this. I didn't have time to go custom engine management with it which I'm sure will fix this.
stock open differential
shifter hole needs covering and shift knob needs glued, or you can pick your own knob.
Speedometer doesn't work because incompatible speed sensor on the W58. Supposedly you can fix this with the Dakota Digital
No trades, cash only.
rswails is offline   Reply With Quote
Old 02-07-2019, 11:14 AM   #2
silviaks2nr
silviaks2nr's Avatar
Sunroof? Engine bay pics?
Old 02-07-2019, 11:22 AM   #3
rswails
no sunroof, added pics
Old 02-07-2019, 11:33 AM   #4
joe645733
joe645733 is an unknown quantity at this point
lol 40k original miles on the motor??
$6.5k?
E85 1j SC300
joe645733 is offline   Reply With Quote
Old 02-07-2019, 11:50 AM   #5
240sex_s14
240sex_s14's Avatar
240sex_s14 is making a name for him/her self240sex_s14 is making a name for him/her self
Send a message via AIM to 240sex_s14
Per forum rules, Must have a Sale price. If you're asking for Reasonable offers, Shoot high and request OBO from buyers.
Clean Car GLWS OP!!!!
Check out my Build Thread!http://zilvia.net/f/showthread.php?t=650464
240sex_s14 is offline   Reply With Quote
Old 02-07-2019, 11:53 AM   #6
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
i hope you put that ECU in some sort of sealed box. leaving it out in the open is asking for trouble. i also hope whoever ends up with this cleans up the wiring..
jumpman2334 is offline   Reply With Quote
Old 02-08-2019, 07:11 AM   #7
silviaks2nr
Thanks for the updated pics, I'm not going to be interested but GLWS.
Old 02-08-2019, 10:49 AM   #8
Te37
Te37's Avatar
Te37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choices
What a beautiful build to see underperforming new owner should love it GLWS
Te37 is offline   Reply With Quote
Old 02-08-2019, 06:12 PM   #9
Zenkify
Zenkify is a well-known jackass
15k and it’s not even a real Kouki
Zenkify is offline   Reply With Quote
Old 02-09-2019, 05:25 AM   #10
240sx_sr20det
240sx_sr20det's Avatar
240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection
A lot of half-ass going on here...
240sx_sr20det is offline   Reply With Quote
Old 02-14-2019, 10:34 AM   #11
rswails
Updated price
Old 02-18-2019, 07:03 AM   #12
rswails
Updated price, pics, and description.
Old 02-21-2019, 08:46 AM   #13
rswails
Bump bump bump
Old 02-21-2019, 10:27 AM   #14
Cowings12
Cowings12 is an unknown quantity at this point
7k and I can pick it up this weekend
Cowings12 is offline   Reply With Quote
Old 02-21-2019, 07:53 PM   #15
RedSnow
RedSnow's Avatar
RedSnow is an unknown quantity at this point
dude, the swap alone was probably more than 7k.
RedSnow is offline   Reply With Quote
Old 02-22-2019, 08:10 AM   #16
nmerriw
nmerriw has a spectacular aura aboutnmerriw has a spectacular aura aboutnmerriw has a spectacular aura aboutnmerriw has a spectacular aura aboutnmerriw has a spectacular aura aboutnmerriw has a spectacular aura about
I'm in SC too, any interest in trades?
nmerriw is offline   Reply With Quote
Old 02-26-2019, 12:38 PM   #17
rswails
Yes. I could trade for a different sport car if MOSTLY STOCK. Cool what part of SC?
Old 02-26-2019, 12:41 PM   #18
nmerriw
Haha well I guess that answers my question, mine is far from stock lol, built boosted 2001 mr2. I'm in Clemson currently, but grew up around Greenville.
Old 02-28-2019, 02:45 AM   #19
Kirbyz
Kirbyz is an unknown quantity at this point
10k cash, cash in hand let me know.
Kirbyz is offline   Reply With Quote
Old 02-28-2019, 08:18 AM   #20
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
fuuuuuck. 10k is a heck of an offer considering all the details this thing has and not being a really kouki.
Take it and run like charlie bucket, op.
Tuners are big bullies
feito is offline   Reply With Quote
Old 02-28-2019, 09:04 AM   #21
rogues13
rogues13's Avatar
rogues13 is an unknown quantity at this point
13k for a car with rotas...
rogues13 is offline   Reply With Quote
Old 02-28-2019, 10:03 AM   #22
Kirbyz
Take my money!
He should well there's 3 more similar car so whoever takes my 10k first lol.
Old 03-01-2019, 04:38 AM   #23
Syrussilvia
Syrussilvia is making his/her stupidity well-knownSyrussilvia is making his/her stupidity well-knownSyrussilvia is making his/her stupidity well-known
The Dakota digital will fix the Speedo issue can confirm and bump for a clean car
Syrussilvia is offline   Reply With Quote
Old 03-04-2019, 11:33 AM   #24
rswails
Show me the other 3, might adjust price if they really are close to mine.
Old 03-04-2019, 08:37 PM   #25
kayless
kayless is an unknown quantity at this point
'Not even a real Kouki' ?????
Is that a real thing? You guys looking for matching numbers now too?
Awe man, he took out the original motor too, now it's not even a 240.
Anyway, got excited for a 96 or under with a kouki front end, cuz newer then 96 is extra emissions regulations in my part.
Just a bit illogical to me considering the S-chassis culture and appeal has been based around frankensteining whatever motor, brakes, interiors, etc... It's a great chassis, not even a good package from the manufacturer.
Wasn't Odessey Van front ends some perverted trend for a bit.
kayless is offline   Reply With Quote
Old 03-05-2019, 01:19 PM   #26
yzrider450f
yzrider450f's Avatar
yzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of lightyzrider450f is a glorious beacon of light
Spoken like a true zenki owner
yzrider450f is offline   Reply With Quote
Old 03-05-2019, 02:08 PM   #27
jumpman2334
ROASTED. this thread just got that much better. thank you YZ.
Old 03-13-2019, 11:13 AM   #28
kayless
I should have posed that different. I'm looking for a zenkie with a kouki front end. The front I want without having the extra issues with emissions.
Really, what is the benefit of a real kouki? Honest question
Old 03-15-2019, 08:08 AM   #29
Fitelite240
Fitelite240 is on a distinguished road
It's just the more favorable look to the masses.
Imagine theres a rebuilt KA-T on 13lbs making 400rwp on a 1995 zenki going for 7k and its reliable as can be with a mint interior.
And then theres a busted rad, blown head gasket and the bay looks like trash of an sr20det. rust spots on the car and missing a seat as well as a headlight for 6k.
Most "non-Schassis" people will consider the the kouki strictly based on looks and that is has a more aggressive look rather than what's there to fix.
I do hate my 95 sometimes just because this stupid door harness wiring and the small tid bits that the 97s and 98s have that was further integrated into the full dash harness. But over all I honestly rather prefer a beautiful Car modify wonder zenki with a stock SR tuned to about 350. Perfect daily car right there IMO.
Fitelite240 is offline   Reply With Quote
Old 03-15-2019, 02:05 PM   #30
97kouki1
97kouki1 has made poor choices97kouki1 has made poor choices97kouki1 has made poor choices97kouki1 has made poor choices97kouki1 has made poor choices97kouki1 has made poor choices97kouki1 has made poor choices97kouki1 has made poor choices
It's rare to have and that resale value and to go even further into it if it's a true 5 speed manual kouki vs a auto it's even more coveted and bumps the price even more.
Other than that not much.
97kouki1 is offline   Reply With Quote
