Old 03-07-2019, 03:04 PM   #1
alex_s817
alex_s817 is making his/her stupidity well-knownalex_s817 is making his/her stupidity well-knownalex_s817 is making his/her stupidity well-known
New Trans Bearing, Where does everyone get their replacement Bearings from!?
Whats up everyone, I'm looking for some help in finding a replacement input shaft bearing for an r154 transmission. Its actually for an Aisin AR5 but OEM has been tough, and I can't find any other option. Hoping the r154 is the same size. I've gotta think there is a bearing supplier out there that has one to this spec sitting on their shelf. Any help is greatly appreciated. thanks!
alex_s817 is offline   Reply With Quote
Old 03-07-2019, 03:09 PM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
why not remove the bearing, take measurements, call your local bearing supplier, and have them match it?
Old 03-16-2019, 08:34 AM   #3
alex_s817
Been there done that, no luck. Which is why I was hoping someone here had replaced theirs and had a definitive answer.
Old 03-18-2019, 06:07 AM   #4
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
this is actually the correct way to do it. bearings comes in many shapes and sizes and they are universal. you can contact SKF Bearings to cross reference the bearings. they would probably have something similar or even a heavier load bearing for you. go for the heavier load bearings. most of the time make sure you use standard and metric measurements.
you need Outside diameter (O.D.) x Inside diameter (I.D.) "shaft size diameter" x the thickness of the bearings. there's also the a tolerance for the I.D. and O.D.
example
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 11-14-2019, 03:15 AM   #5
denishbiaze
denishbiaze is an unknown quantity at this point
I think you can contact North International Limited, they offer the best bearings for all-purpose. I had bought SKF S71920 CD/HCP4A bearings from them at an affordable price.
denishbiaze is offline   Reply With Quote
Old 11-14-2019, 10:36 AM   #6
jedi03
+1 on call bearing manufacturers if the local one doesn't have em...thankfully I'm in an area with lots of local dealers/transmission shops for when I run into the same...
