#1141 | |
![]() Join Date: May 2006
which VE head do you have? P11 or P12? you'll need the valves and machine them for clearance. also machine the retainer to these specs like this https://1drv.ms/u/s!AqTGJCzpW1E8hEmP...NM1fZ?e=Ks7ZId https://1drv.ms/u/s!AqTGJCzpW1E8hEpd...R2D_E?e=eRk8bC I believe those are in metric so you'll understand them or a machinist will.
18g and 20g turbo users click on me http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html Last edited by s13silvia123; 09-10-2019 at 07:30 PM.. |
#1144 | |
thank you |
#1145 |
#1147 | |
![]() Join Date: Jun 2003
Trader Rating: (130)
https://www.mazworx.com/store/p/370-...shaft-Set.aspx |
#1149 | |
#1151 | |
#1152 | |
Jose Beltre look for him on facebook. i sort of forgot his user name on here. maybe Seablt something like that. i bought a lot of stuff from and his does deliver them on time or for a little more depends on or how you want your stuff done. you'll also have to understand that there's also a lead time for the custom parts too.
#1156 |
#1157 |
Oh he's well aware, we talk all the time. In the end I think a money shift with a transient overrev to 9600 may have caused some float. I've done a handful of track events with it but a few engine problems as well as having two kids since I've gotten it has cramped my style. In the end it's just been easier to take the daily driver out on the track...
The longer story is I bought the car a little over 2 years ago. I took it out on track once and the sweet custom lightweight alternator bracket broke, but I also Miss shifted and had that small overall. Car drove okay and got me home but I had cracked a few retainers. Kid was born, over the winter got the head fixed up or so I thought, and swapped to the z33 transmission. Last year tracked it a few times with some various issues with the tune. Def actually passed through town and we did some street tuning. Last event last year it was down on power. Had another kid this year and I couldn't get the car to start I ended up finding a damage spark plug on cylinder 4. Took the head off and majority of the intake valve guides head cracked off and the head has significant foreign object damage. So, I need a new head as well as two new pistons. With two kids under two it's a little hard to work on the car much less update a build tread on a dead forum.
S13, SR20 - Track day fun |
#1158 |
So who here is running a EFR and a twin or single port TS gate??
I have a single port, and I suspect it is unable to properly control boost via solenoid. No matter what we did, it wouldn't do more than wastegate pressure. Looking into a twin port now, but just curios as to why the single port wouldn't work . |
#1159 |
![]() Join Date: Nov 2012
![]() Feedback Score: 15 reviews
If it's unable to control boost, i'd expect the boost to keep creeping up. Your issue is the other way around.
Could that point out you have way too much backpressure? I.e. your turbine housing is too small? Maybe a backpressure gauge could tell you more whether that's your issue.
Need UKDM/EUDM/JDM/RHD Nissan parts? Hit me up ![]() Insta: skids14 |
#1160 |
Its a T4 twin scroll, so 0.8 (or .93 as BW EFR measure it) turbine housing. We pulled the exhaust off from the cat back, so it was only downpipe, and still the same issue. So it wasn't a back pressure issue. We picked up less than 8WHP when we pulled the cat, so definitely wasn't a back pressure issue. And the same occurred.
Gate was just wide open it seems regardless of duty cycle. We could get it to spike mid range, but it always went back to wastegate pressure and tapered off by 7K RPM. |
#1161 | |
I was referring to the backpressure between engine and turbine wheel. So pre-turbine pressure.
#1162 |
There shouldn't be. Its a Sinco custom top mount mani with I think 1.25 primaries. Its a semi equal length twin scroll manifold. Should be fairly uninhibited flow to the turbine.
#1163 | |
To me it sounds as if there is something blocking you from making any more power. You said it yourself, it doesn't hold anymore than wastegate pressure. So something seems to be blocking the air coming out of the turbine, the pressure is strong enough to push against your wastegate spring, preventing the turbine from making any more boost. Could it be that the turbine housing/wheel combination is the "blockage"? You may want to check out this article: http://www.stavtech.co.uk/home/exhau...nes-never-good
#1164 |
I doubt its the turbine wheel as it's the same turbo setup evo boys have made 600+awhp on. So I doubt asking 450whp with of airflow is a limiting factor. Match bot states it should be good for an easy 450 whp
Also, we can get it to spike in the mid range, its just unable to hold the pressure the more revs we give it. |
#1166 |
So we checked a few times to confirm. I may actually swap the vacuum lines now that time home, but pretty sure they are ran correctly. We tried both the EFR and the MAC valve
Single.port internal turbosmart iwg75 gate |
#1167 |
![]() Join Date: May 2009
Hey guys quick question. Does the P12 Valve cover work on the P11 head? If so, would the P11 valve cover gaskets work with the P12 Valve cover?
Thank you very much for any input.
#1170 |
Sorry to bother everyone but I have another question. So I have finished setting up my motor, bled the coolant system and its maintaining a constant 158 degrees Fahrenheit.
Its running a Nismo thermostat, Clutch fan setup with a GKTECH fan. Is it normal to see 158 degrees and not get any warmer? Thanks
