Old 01-19-2005, 02:18 AM   #1
AllenRPS13
AllenRPS13's Avatar
AllenRPS13 is an unknown quantity at this point
KA My car shakes when I start braking at high speed... What's wrong?
When I drive at about 80mph and i step on my brake pedal harder, my car begins to shake... so weird... really don't know why. recently i have changed the front and rear brake pads, and then the problem exists... thanks for any help or suggestion!
~小アレンのリベリオン~
いくせ, 勝負た! 轟こう, オレのKRMS13!!!
オレの得意技!蹴り進入!角度の少ないドリフト!
AllenRPS13 is offline   Reply With Quote
Old 01-19-2005, 02:23 AM   #2
vegita319
vegita319's Avatar
vegita319 is an unknown quantity at this point
Send a message via AIM to vegita319
Have u looked at ur rotors? They might be warped. Some people also find that they get alot of brake shimmy when the tension rods are worn. Check both of those two problems.
vegita319 is offline   Reply With Quote
Old 01-19-2005, 07:54 AM   #3
Bone
Bone is an unknown quantity at this point
Send a message via AIM to Bone
10 to 1 odds its Rotors.
Bone is offline   Reply With Quote
Old 01-19-2005, 09:52 AM   #4
Silvia Wannabe
Silvia Wannabe is an unknown quantity at this point
I'll take 100 to 1 on rotors. Either have them machined or replaced. Go Drilled if you do replace them this will keep you from overheating them again.
Saving Penny's For a real Car
Hopefully one will find it's way into my life
Silvia Wannabe is offline   Reply With Quote
Old 01-19-2005, 09:57 AM   #5
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
I always thought drilling was mostly for less rotating mass and some heating benefits while vented rotors aided more in cooling. Hmph..
wootwoot is offline   Reply With Quote
Old 01-19-2005, 10:01 AM   #6
Phlip
Yes, I look like that
Phlip's Avatar
Rotors it is
Weirdo
And I write too!
Old 01-19-2005, 11:15 AM   #7
**rOb**
**rOb** is an unknown quantity at this point
same
i have the same problem, hard breaking at high speed... car shakes till i reach a lower speed, didnt have a chance to look at rotors. anyone know the priec to get them machined?? thanks
-rob
**rOb** is offline   Reply With Quote
Old 01-19-2005, 11:45 AM   #8
oO0OthinkO0Oo
oO0OthinkO0Oo's Avatar
oO0OthinkO0Oo is an unknown quantity at this point
Send a message via AIM to oO0OthinkO0Oo
s14 ..
in my area it's about $8 per rotor. not too big of a deal.
.::kris::.
oO0OthinkO0Oo is offline   Reply With Quote
Old 01-19-2005, 11:51 AM   #9
Bone
yeah its like $35 or $40 for new OEM's from a parts store.
Old 01-19-2005, 12:19 PM   #10
wootwoot
Be careful for who turns them. A lot of people will turn them to fast and they will be warped soon again.
Old 01-19-2005, 12:40 PM   #11
Bryants95240sx
Bryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the rough
wow, really its like 15 bucks for new rear rotors at napa here ,althoug the front might be that much i havent checked.
Bryants95240sx is offline   Reply With Quote
Old 01-19-2005, 01:44 PM   #12
vegita319
vegita319's Avatar
there a link to slotted brembos for 70 bucks each. I'll look for it if ur interested. If not, I won't bother looking for u.
Old 01-19-2005, 03:02 PM   #13
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
THE ROTORS ARE NOT WARPED, ITS THICKNESS VARIATION. This has got to be the most misunderstood automotive problem. A floating caliper assembly will cancel out that but the thickness variation it will not. A solid rotor will be the best, cross-drilled and slotted are mostly for looks in my opinion. The more mass you have the better the heat can be dissipated.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 01-19-2005, 04:00 PM   #14
97DubTruck
97DubTruck is making a name for him/her self97DubTruck is making a name for him/her self
Listen to Robert Plant. Blanks are where its it.
97DubTruck is offline   Reply With Quote
Old 01-19-2005, 05:32 PM   #15
w1ngzer0
w1ngzer0 is an unknown quantity at this point
Send a message via AIM to w1ngzer0
what about if a car can't keep alignment and it shakes when you brake? could it be the tension rods then?
w1ngzer0 is offline   Reply With Quote
Old 01-19-2005, 06:31 PM   #16
ledzeppelin240
Yes in that case I would start checking out suspension components. The best thing you can do is get the car on a hoist and take a good look over everything, with a journeyman mechanic or knowledgeable person. You can learn a lot from the right people if you ask questions. That way maybe3 something you overlooked is caught by them.
Old 01-19-2005, 07:55 PM   #17
s14turbosilvia
s14turbosilvia has a little shameless behavior in the past
Send a message via AIM to s14turbosilvia
wheel bearings.
92 coupe, teh sex.
s14turbosilvia is offline   Reply With Quote
Old 01-19-2005, 08:01 PM   #18
MasterOFDrift
MasterOFDrift is an unknown quantity at this point
Send a message via AIM to MasterOFDrift Send a message via MSN to MasterOFDrift
drilled rotors are no good if you are in a wet climate they tend to crack after time
i just have slotted brembos that works for me.
MasterOFDrift is offline   Reply With Quote
Old 01-19-2005, 11:39 PM   #19
ledzeppelin240
From wheel bearing runout you get a low brake pedal...
Old 01-19-2005, 11:50 PM   #20
Nismo180
Nismo180's Avatar
Nismo180 is a well-known jackass
WOOHOOO someone else knows what they are talking about!!!
A word on slotted/etc. For the most part yes, high quality blanks(Brembo blanks will really do it for just about everything a street car will see) are the best for braking with street pads most contact area. On pads with no gas output(anything suitable for street use) slots/holes are useless.
Drill holes all these really do is increase a rotors tendency to crack, until you get into really high grade materials(See also Porsche brakes) then it's a different story.
Slotted are really the best of both worlds, still get maximized contact area, you can slap on a set of track pads and they will work great because the gasses are getting vented, and best of all they look pretty behind big useless rims I personally use and love Powerslots and Hawk HPS pads on my daily driven auto-X car and for the occasional lapping days I just swap on teh HP+ good times are had by all.
If you want to know alot more about brakes go to the Brembo website and read the FAQ wait till you get to the part about warped rotors woo would have thought the pads were depositing uneven?
Nismo180 is offline   Reply With Quote
Old 01-20-2005, 01:02 AM   #21
XxJaPxOxNeEs23xX
XxJaPxOxNeEs23xX's Avatar
XxJaPxOxNeEs23xX is making a name for him/her selfXxJaPxOxNeEs23xX is making a name for him/her self
Send a message via AIM to XxJaPxOxNeEs23xX
i think its alignment. check your tie rods and tension rods. check if its out of alignment and then also check if the bushings are worn out on ur suspension parts.
XxJaPxOxNeEs23xX is offline   Reply With Quote
Old 01-20-2005, 02:25 AM   #22
AllenRPS13
AllenRPS13's Avatar
yes, that's what i think also... i think my alignment got some problems because i have not checked it for a long time already... i hope that's the reason...
~小アレンのリベリオン~
Old 01-20-2005, 08:06 AM   #23
sykikchimp
WOW addicted
sykikchimp's Avatar
actually cheaper street pads are the ones that tend to outgas these days. Quality track pads like cobalt, or carbotech don't have this problem.
and even Porsche's 'drilled' rotors crack at the holes.
Old 01-20-2005, 12:37 PM   #24
AKADriver
AKADriver's Avatar
I'd hate to crack one of those bling ceramic rotors. The regular metal Porsche drilled rotors can crack, the race cars don't run drilled (usually).
I'd only run a slotted rotor if the car had a problem with water buildup on the brakes. My GTI VR6 had this issue, my 240SXs and other Japanese cars never did for whatever reason. When I'd drive home in the rain on the interstate, I had to lightly pulse the brakes once or twice before I actually wanted to stop to dry the brakes off. This never happened in traffic or at low speeds, only when I'd been cruising at 65+mph for 5 miles or so. Slotted rotors would wick that water away immediately. I think it's just because that car's brakes were so damned BIG - something to think about for those of you with GT-R brakes or similar...
Old 01-20-2005, 01:37 PM   #25
Silvia Wannabe
What is drilling for then? I allready know about the weight thing.
Old 01-20-2005, 08:43 PM   #26
w1ngzer0
who are u talking to....
Old 01-20-2005, 09:48 PM   #27
240silvia
240silvia's Avatar
240silvia is an unknown quantity at this point
Send a message via AIM to 240silvia
Rotors baby..... change them bitches!
240silvia is offline   Reply With Quote
Old 01-21-2005, 02:02 AM   #28
XxJaPxOxNeEs23xX
To allen180sx
Old 01-21-2005, 02:37 PM   #29
ledzeppelin240
Alignment will not cause a shake or shimmy. How does changine toe, camber, caster and making a car drive straight fix a shimmy or shake. It is a pulsation in the pedal when braking, almost like ABS but without the "cool" sound. That is thickness variation and it is a large problem with Disk brakes.
On a FWD car I would not reccomend turning the rotors just replace. There is a lot of components up front and you want all the mass you can get out of the rotor. If you drive your car hard I would not suggest turning the rotors, just replace. Trust me it is worth it.
Old 01-29-2005, 07:19 PM   #30
S13_Showoff
S13_Showoff is an unknown quantity at this point
I have a question guys, I'm experiencing the same problems and I want to change my discs but I have a 200SX which is the same as the 240SX only that mine is european and has a CA18DET. I live in the caribean and the US is the easiest for me to order parts. Will the 240SX discs fit and brake pads??
S13_Showoff is offline   Reply With Quote
