Old 01-20-2005, 04:51 PM   #1
hybrid240
hybrid240's Avatar
hybrid240 is an unknown quantity at this point
SR AFC reads 5.3+v from MAF
installed a mystery turbo and now airflow % is off the charts. When it hits 100% know signal skyrockets. I know the knock signal is kinda wack on the s-afc 2 but it cant be good. So I installed 50lbs topfeeds and bought a z32 maf and tomei adapter harness. Only problem is instructions are in jap. I did a search on here and fresh alloy. Can anyone translate?
thanks
boostin through a neighborhood near you!
hybrid240 is offline   Reply With Quote
Old 01-21-2005, 07:55 AM   #2
hybrid240
hybrid240's Avatar
emailed phase2 and they said it should matchup wire for wire (color). ill post tonight how that works out.
Old 01-22-2005, 06:03 AM   #3
hybrid240
hybrid240's Avatar
it is straight forward wire for wire install. new maf is no where close to maxing out.
what is a safe knock level reading on an s-afc under boost?
Old 01-22-2005, 06:06 PM   #4
nissantuner22
nissantuner22's Avatar
Trader Rating: (-1)
nissantuner22 is on a distinguished road
Feedback Score: -1 reviews
Send a message via AIM to nissantuner22
I wish I knew the answer, bump!
Current Project: Operation: N/A SR: 93 Silvia Q SR20DE Engine with go fast goodies. ,
"Common problems 240sx's suffer from are curbs, trees, ditches, and other immovable objects."thx247
"on the tounge... there is no guardrails."- citizen
nissantuner22 is offline   Reply With Quote
Old 01-23-2005, 05:43 PM   #5
hybrid240
hybrid240's Avatar
i have bigger than stock turbo, 50lbs inject, greddy frontmount, s-afc 2, wideband, and other bolt-ons at 18ish lbs.
knock calibration is set at 30something/ 40something
under full boost knock reads in the lower 200s.
what do you hit?
