![]() Hey everyone, I have been trying to verify where these wires go. I have searched the FSM, as well as Battery and fusebox relocation posts for the answer with no luck.
This wire comes out of the fuse box. i belive it connects to the alternator but just want to confirm. https://www.instagram.com/p/B6uUQCAg..._web_copy_link This wire is on the same branch that connects to the starter. I am not certain if it connects to the alternator as well or if it goes all the way to batt +. https://www.instagram.com/p/B6uURNxA..._web_copy_link Thanks for your help Last edited by IDKanything; 12-30-2019 at 09:48 PM.. Reason: couldnt get photo links to work so hard posted them |
![]() Join Date: Aug 2007
![]() ![]() ![]() Feedback Score: 10 reviews
Regarding Question 2: Hard to tell from the picture, but many folks forget that the alternator has a ground wire ring terminal (the alternator grounds itself to the engine, but the wiring harness also has an alternator ground connection).
Does your alternator have a ground wire connection yet?
P.A.T.T. |
Yes, I already have the ground at the back of the alternator its a little 12-8ga wire with a ring terminal. The second wire is a heavy gauge like a battery cable. I can take a different photo if that would help. I had to cut these down quite a bit to fit the 500kb limit of the forum.
Thank you both for the replies. |
![]() Join Date: Aug 2019
This post helped me out as well I was wondering where that goes to just put a junction block in your car and route your batteries positive terminal to that then the alternator positive and then last the starter I think? That would work
Yeah like an inline fuse works best forgot about that part your absolutely right id do a 100 amp battery inline fuse maybe a 80amp alt fuse and starter fuse. I learned that from watching the sr20det swap tutorial on yt tbh.
I'm back with another question, I know this is a ground wire but where are the two connection points other than the battery? I am thinking it should be the side of the block, to chassis then batt Neg. Is that correct?
Link to wire in question. https://www.instagram.com/p/B64PDmYg..._web_copy_link Thank you |
#11 | |
The battery ground wire in question goes from the negative battery terminal, to the chassis (which I believe is around the battery tray area, I can confirm when I get home and look at my car,) then to the engine, which I'm pretty sure is the intake manifold on a S14.
P.A.T.T. |
