Old 01-19-2020, 05:25 AM   #1
zachvirus
zachvirus is an unknown quantity at this point
Built SR20 complete drop in
Location is Columbia, SC
$4,500 OBRO
I have a built s13 sr20det redtop.
It was assembled in 2017 and has less than 5k on it, as I barely have driven it. I have machining paperwork. Car made 387whp on 13psi. Built for 25psi. Never got a chance to turn it up due to failing CAS at the time.
I most definitely will forget something but here we go.
S13 SR20DET REDTOP
Brian Crower 272 cams
Brian Crower Titanium Valve Springs and Retainers
Tomei Rocker Arm Stopper
S13.4 Hybrid Valve cover with 10AN fitting
Mazworx Valve Cover Dress up kit
VK56 Smart Coils
10AN Oil catch can setup
FReddy Intake Manifold
OEM Throttle Body
GKTech S14 Eccentric TB Pulley
Ebay Top Feed Fuel Rail with 8AN unions
FIC 1300cc Injectors
Intake/TB Thermal Spacer
Borg Warner S256RS T3 .63ar
Black TurboGuard Compressor Cover
Heat Blanket
4AN Oil Feed setup
12AN Turbo Oil Return setup
XSPower T3 Twin Scroll Turbo Manfiold
Multi layer exhaust gaskets everywhere
Tial 44mm EWG 13lbs spring(all springs included) and EWG tube
Modified CX Racing Downpipe
Hallman Pro RX Manual Boost Controller(with both springs)
Tial Q BOV (all springs included)
CP Pistons 8.5.1 86.5mm
Eagle Rods
Full ARP stud kit (mains, headgasket, etc)
ACL Thrust Washer
ACL Main/Rod Bearing set
Tomei 87mm Metal Headgasket
Brand New Chain/Tensioner setup
Aluminum Radiator
Custom 20AN Upper/Lower Radiator Setup with thermostatic sensor bung
14" Hayden Fan
Lightweight Pulley setup
Nissan Quest Alternator
Tomei Oil Filter Adapter Plate
Circuit Sport Oil Filter Relocation kit
S13 SR Transmission
Clutch Master cylinder to Slave Cylinder hardware
ISR Short Throw Shifter
Z1 Steel Driveshaft
Competition Stage 3 Clutch Kit
Nismo Lightweight Flywheel
Custom HMIC piping setup
All couplers and T-Bolt Clamps
Nismo Motor Mounts
Peak Performance Trans Mount
N62 billet blow thru MAF
Custom wire harness tuck
#62 Redtop ECU tuned by RS Enthalpy
Tuned for E85
Almost all parts have the same mileage as the motor or less.
Parts to be included but not pictured:
AGP .75ar Twin Scroll turbine housing with V-Band exhaust
Tial QR BOV hat
Spare nismo flywheel
OEM S13 SR intake manifold
Spare OEM Crank Pulley
Circuit Sport Side Feed fuel rail (GOLD)
Solid Motor Mounts
OEM S13 SR cams and valve springs/retainers
Handful of V-Band flanges and clamps
Handful of T-bolt clamps
Some leftover 20AN and 10AN hoses
Misc SR sensors(CAS Module, TPS, etc)
Purple silicone radiator hoses(Upper cut for fan switch adapter)
Videos of Motor running before being removed.
https://youtu.be/3pN__krkHQI
Car on Dyno with motor. Can include exhaust if requested.
https://youtu.be/eTqYuLwtKNc
Obviously this is a PICK UP preferred. WILL NOT SHIP. Will deliver for a fee per distance.
Please keep your negative or ignorant comments to yourself. Its distasteful and pointless. But if you feel the need to get yourself off.
https://www.pornhub.com/view_video.p...h5d615a8f33a7e
Last edited by zachvirus; 01-27-2020 at 02:44 PM.. Reason: Addition info and pictures of motor removed
zachvirus is offline   Reply With Quote
Old 01-19-2020, 07:09 AM   #2
Turbosauce74
Turbosauce74 is an unknown quantity at this point
Looks great, sure wish I seen something like this when I was in the market. Glws!
Sent from my SM-G965W using Tapatalk
Turbosauce74 is offline   Reply With Quote
Old 01-20-2020, 02:41 PM   #3
zachvirus
Thank you sir
Sent from my SM-G965U using Tapatalk
Old 01-21-2020, 03:58 PM   #4
zachvirus
Bump
Old 01-22-2020, 06:09 PM   #5
zachvirus
Bump
Old 01-22-2020, 06:30 PM   #6
S14rebuild
Any tuning issues or difficulties with the blow thru maf setup?
Old 01-22-2020, 06:32 PM   #7
zachvirus
Just a little more tweaking involved, but nothing that can't be done.
Old 01-22-2020, 07:19 PM   #8
speedgod^s13
speedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond repute
Send a message via AIM to speedgod^s13
Where'd you relocated the fuse box to?
speedgod^s13 is offline   Reply With Quote
Old 01-22-2020, 07:19 PM   #9
zachvirus
Behind the radio, in that little pocket at the end of the dash on the passenger side.
Old 01-23-2020, 02:13 PM   #10
zachvirus
Bumpski. Gonna pull the motor soon cause bored.
Old 01-23-2020, 03:33 PM   #11
HellaSexyS13
HellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-known
awesome build, GLWS
HellaSexyS13 is offline   Reply With Quote
Old 01-23-2020, 08:36 PM   #12
zachvirus
Originally Posted by HellaSexyS13 View Post
awesome build, GLWS
Thank you sir. Whoever buys it will have tons of fun with it.
Old 01-24-2020, 10:20 AM   #13
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
if you wanna sell that valve cover separately, let me know!
Old 01-24-2020, 07:33 PM   #14
zachvirus
Pulled the motor tonight. Still for sale
Old 01-25-2020, 09:59 AM   #15
zachvirus
Information updated. Additional items added. Pictures added.
Old 01-25-2020, 06:00 PM   #16
S14rebuild
Bruhhhh...... why is there a pornhub link in ur ad?! Thanks
Old 01-26-2020, 11:23 AM   #17
zachvirus
Bump
Old 01-26-2020, 12:36 PM   #18
JDM240z
JDM240z's Avatar
JDM240z is an unknown quantity at this point
For reals ��
Close race though. I thought number 2 had it in the bag.
JDM240z is offline   Reply With Quote
Old 01-26-2020, 02:08 PM   #19
zachvirus
Originally Posted by JDM240z View Post
For reals ��
[emoji23][emoji23][emoji23] always next year
Old 01-27-2020, 02:45 PM   #20
zachvirus
Price adjusted
Old 01-28-2020, 03:48 PM   #21
zachvirus
ttt
Old 01-29-2020, 06:15 PM   #22
zachvirus
Bump dayyy
Old 01-29-2020, 07:56 PM   #23
speedgod^s13
Did you have to cut any wires? Still able to run a radio after that?
Old 01-30-2020, 02:35 PM   #24
zachvirus
Yes i have a radio and room for all accessories. Harness was modified.
Old 02-01-2020, 05:34 AM   #25
zachvirus
ttt
Old 02-03-2020, 06:56 AM   #26
zachvirus
Bump
Old 02-04-2020, 08:03 PM   #27
zachvirus
Tuesday bumpski
Old 02-06-2020, 07:46 PM   #28
zachvirus
ttt
Old 02-07-2020, 11:02 AM   #29
ronnieronron
ronnieronron is on a distinguished road
i dont need but i want...
also SC
ronnieronron is offline   Reply With Quote
Old 02-08-2020, 03:41 PM   #30
zachvirus
SOLD SOLD SOLD
