Old 01-24-2005, 01:26 PM   #1
d4vech3n
d4vech3n is an unknown quantity at this point
Another dumb vlsd question
Will an VLSD from an s14 with ABS bolt into s14, non abs, open diff without new output shafts?
d4vech3n is offline   Reply With Quote
Old 01-24-2005, 03:44 PM   #2
projectRDM
projectRDM's Avatar
No. And you knew that.
FORMERLY R240NA
Old 01-25-2005, 06:45 PM   #3
d4vech3n
All jokes aside, I really don't know.
All the VLSD tech installs say you need output shafts but theyre swapping in an J30 VLSD. The Zilvia install says you will have the correct output shafts if the lsd is from a 240 but then i get answers from people like you telling me I need new output shafts.
So with an VLSD from an s14 (with abs and vlsd of course), I will still need the output shafts from a vlsd s14 to put into my open diff s14 240?
Old 01-25-2005, 07:20 PM   #4
orion::S14
orion::S14's Avatar
Yes, you need VLSD output shafts...they can be from a '95-96 J30 diff, or an S13/S14 VLSD.
Open diff shafts WILL NOT WORK.
You must use VLSD specific output shafts.
The Zilvia install says that probably b/c if you get a VBLSD form a 240SX, they typically come with output shafts already in the diff.
"So with a VLSD form an s14...", you will have all the parts you need to put that into your S14. As long as it comes as a complete diff...
- Brian
www.KA24DEvelopment.com
Old 01-25-2005, 08:00 PM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Hmm...funny, cuz i bought a VLSD from venus and it bolt rite up onto my non-abs non-lsd SE. Its off a JDM s14. Only thing that i did was I used the drive shaft that i got with it cuz the one I had was off. *cant remember if it was shorter or longer...shorter iirc*
CLICK HERE!!!
Old 01-25-2005, 08:20 PM   #6
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
i dont believe u ray......... j/k how much was that jdm diff?
infinitexsound is offline   Reply With Quote
Old 01-26-2005, 01:11 PM   #7
Agent_S13
Agent_S13's Avatar
Agent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to all
I put in an S14/J30 (w/ abs sensor) into my base S13 (non ABS/LSD) and all I switched was the differential cover and got some ES bushings/longer bolts for it. Everything else was fine.
1) Didn't need to swap driveshafts -- my S13 was shorter than the S14 I received (said 95 240sx on it) and the length was negated by the fact that my S13 differential cover was shorter than the S14/J30 one.
2) Also, no problems with the output shafts either. Everything bolted up together with no problems (It was a 96+ J30 LSD with 6-bolt pattern).
I've only had the VLSD for a few months and I have not had any problems driving the car... except for the gear ratio (3.92 vs my stock 4.08 but its very neglible and I could care less)
-Aaron
'91 240sx coupe
Agent_S13 is offline   Reply With Quote
Old 02-07-2005, 03:30 PM   #8
CHARLIE2020
CHARLIE2020 is an unknown quantity at this point
Send a message via AIM to CHARLIE2020 Send a message via Yahoo to CHARLIE2020
Sorry maybe the answer was up above allready but anyhow.........
Will a 96 J30 VLSD w/ABS work on my S13 coupe......because this has ABS what problem will I run into.......do I need to get the J30 driveshaft also?
Please advice
Thanks
Charlie
CHARLIE2020 is offline   Reply With Quote
Old 02-07-2005, 04:22 PM   #9
projectRDM
projectRDM's Avatar
Please advice
Thanks
Charlie
How about you keep asking the same question in every LSD thread and maybe you'll get an answer.
Or you could follow any of the links provided and find out on your own, without the need to have it spoonfed to you.
FORMERLY R240NA
Old 02-07-2005, 05:56 PM   #10
CHARLIE2020
How about you eat shit.....lol j/k
Wuta u know about I got the whole damn 96 J30 VLSD Rear end with 5 lug conversion and drive shaft and brakes for $200 and allow wheels............swallow that shit powder puff!...lol
Old 02-07-2005, 06:13 PM   #11
projectRDM
projectRDM's Avatar
So you paid $200 for a diff and a bunch of useless shit that won't work on your car.
Please post pics of the hubs and driveshaft installed, I'd love a good laugh, especially when you realize the driveshaft from a J30 is over eight inches longer.
FORMERLY R240NA
