#121 |
![]() Join Date: Sep 2012
![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
Suprareal's S13 FB build (sr20det eventually)
This covid plague has really slowed down business for me like most and instead of going insanely bored I decided to start on my roll cage.
It will be a full cage with interior Im using typical DOM tubing 1.5 .095 wall Started with stripping the interior and sound deadening. I will be adding back some new deadening after though. ![]() ![]() I built the front boxes outside of the car for a much easier job when they need to be welded in ![]() Harness lap belt bolt on plate. You can simply use one of the stock bolt holes with your harness but I found this centered the bolt allowing the strap to come out of the carpet hole much cleaner ![]() The rear plates counter the chassis nicely to get great coverage ![]() I?m TIG welding the entire cage minus the base plates to chassis. The entire main hoop was built and welded outside of the car ![]() I?ve built a few cages in the past but never with interior. Finding it a lot more difficult to build working around the panels ![]() ![]() ![]() The rear section I decided to do a little differently than a standard X. Since these are extra added tubes not needed for a standard cage you have more design freedom. This to me was unique and gave me a little less blindspots on the driver seat in comparison to the X design ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
#122 | |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
No worries thanks for the response. Cage is looking fire! Sent from my iPhone using Tapatalk Pro
#123 |
After the windshield and A pillar bars were finished it was time to drop the cage down in order to weld the tops. A lot of people will skip this and be left with a unfinished cage
I do this by simply pushing the cage forward till it drops off the boxes. ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
#124 |
With that finished the dash bar could be made along with the mounting brackets for the steering column and fuse boxes
![]() ![]() ![]() ![]() Before I move onto the door bars it?s easier to trim the dash, carpet, and any other panels now. ![]() ![]() ![]() I used my spare dash to cut since I can?t see myself using my original Uncracked dash. This dash will be reupholstered and have the top protrusions cleaned up ![]() ![]() I?ll still be using the lower half of the s14 rear seat ![]() Sent from my iPhone using Tapatalk |
#125 |
Work turned around when everyone got their stimulus checks. The past 2 weeks I was lucky to get a hour a day on my cage
A lot of thinking and changing my mind on the door bar designs and I finally decided on this style because they clear my seat perfectly, required only minor trimming of the door panel, and my legs/elbows won?t hit them when getting tossed around drifting Vertical bars will be added to them ![]() ![]() ![]() A pillar gussets nicely contour the chassis ![]() My bride reclinable sat way to high causing my head to hit the a pillar bars ( I?m 6?3?) so I picked up this Bride Cusco XL seat. For the first time I have a authentic seat! ![]() Rear trim was further trimmed to fit. Now is in 3 removable pieces ![]() My buddy from Socal auto image came by to get a part welded. My twin in Silvia form (My rear fenders are off and changing to type3) ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
#126 |
With the door bars finished up I was able to prep and mask for paint. The color is a mix of body color and black but turned out straight black
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
#127 |
Decided to throw a little bit of deadening back in to reduce the tin canning of the sheet metal
![]() Interior is going back in little by little. My dash is being wrapped before it goes back in ![]() ![]() Sent from my iPhone using Tapatalk |
#128 |
Custom cluster I made and had a friend draw up and cut decals for imitation gauges since none of mine worked anyways
![]() ![]() Interior is all back together now Had my interior guy wrap the dash. It was his first dash so it?s not perfect but I think it turned out great. New gauge pod for the ac hole and I threw the digital climate control back in. It?s just wired so it lights up. ![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
#130 |
#132 | |
I run a full size battery in that box. It wouldn?t fit where the spare is without making a big bulge in the carpet. To me this plastic box is clean, I personally hate exposed battery?s/ boxes. I may later make a delete panel to hide the rear section and have it wrapped the same material as the dash though Sent from my iPhone using Tapatalk |
