Old 01-05-2023, 04:04 PM   #1
srh666
srh666's Avatar
srh666 has made poor choicessrh666 has made poor choicessrh666 has made poor choicessrh666 has made poor choicessrh666 has made poor choicessrh666 has made poor choices
S14 fuel sending unit: change 4pin(96+) into 3pin
Can a 4 wire 96+ fuel sending unit be re-pinned for 3 wire and still function?? Leaving out the temp sensor wire not found in earlier tanks?
srh666 is offline   Reply With Quote
Old 01-05-2023, 04:28 PM   #2
Kingtal0n
Kingtal0n's Avatar
Its just 3 wires you need on one side that go through to the other side. Look at one side and decide which wires go where, then wire it up. I don't really understand the question. You can for example use the 3 wires for something else entirely just by looking at it and wiring it however you want.
I wouldn't bother repinning though, just cut them and solder then with fuel approved heat shrink if needed. Make sure to use an open flame near the mouth of the fuel tank ofc or it won't be very exciting.
Old 01-06-2023, 12:58 AM   #3
srh666
srh666's Avatar
Can a working sending unit from a 1996 function correctly in a 1995?
Old 01-06-2023, 07:36 AM   #4
jr_ss
I?d look at both wiring diagrams and rule out what the differences are between the 3 and 4 wire. King is correct in that if it?s just and additional wiring circuit not used on a 95, which it most likely is, it should work if wired correctly.
Old 01-06-2023, 07:43 AM   #5
Kingtal0n
Kingtal0n's Avatar
I used a 1998 fuel tank in my 96, connected the fuel level fine works to this day. I dont see why 95 wouldnt work with 96. I understand now your question is deeper than wiring as it involves resistance and the cluster though. I think mine changed a wire somewhere as well I now have 3 and one of the tank toppers had 4 but I've switched to an S15 tank topper which only has 3 and now I dont know which one has had what but... tank level works so
and by works of course I mean that I get 120 miles out of the first 1/4 tank, 65 miles out of the next quarter, 35 miles out of the third quarter
*shakes fist in futility muttering something about triangles don't belong in cars
tinyurl.com/4l80er
Old 01-06-2023, 07:53 AM   #6
AKADriver
AKADriver's Avatar
The fuel sender resistance should be the same on all S14s.
Old 01-06-2023, 09:05 PM   #7
srh666
srh666's Avatar
Thanks guys
Old 01-07-2023, 07:04 PM   #8
seto_s14
seto_s14's Avatar
seto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud of
Send a message via AIM to seto_s14
i have a 3 pin one with no cracks that came off a running 1995 (10/95 and onward use 4-pin i believe, basically OBD-II uses 4 pin and OBD-1 uses 3 pin). $60 shipped to Florida
San Gabriel Car Detailing
https://www.ocdshine.com
seto_s14 is offline   Reply With Quote
