Old 04-10-2023, 10:56 AM   #61
OaxKouki
OaxKouki's Avatar
OaxKouki is an unknown quantity at this point
Did you ever figure out your a/c only blowing on the highest setting? I had that problem for YEARS before I replaced the blower motor resistor and solved the problem.
OaxKouki is offline   Reply With Quote
Old 04-10-2023, 01:27 PM   #62
JrDarknes
JrDarknes's Avatar
JrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud of
Yea, I had a loose connection to my blower motor from my prototype harness I made. Once I fixed that it has been working fine ever since.
Originally Posted by tuzzio View Post
Goooood updates as always. I know I said it on IG, but the wideband in the OEM cluster is gangster as fuck.
Thanks man I appreciate it, I might have to bother you again about the spraying the boost gauge bezel black. Kind of struggling to remove it. Was thinking of getting some small towels and using two vice grips on it.
Instagram: Nismo_Lk
JrDarknes is offline   Reply With Quote
Old 12-18-2023, 10:49 PM   #63
JrDarknes
JrDarknes's Avatar
When I used to read the build threads on here. I was always shocked when I would see people build such nice cars & then part them out. I never could understand why.
Now that I am older, I definitely see how that ending is a possibility. When my car was fully stripped out for the sound deadening. Seeing it all dissasembled made me really think about letting this car go. I literally could of just pulled the engine and dropped the subframe and just called it quits.I hate giving up but man I was like it would be sweet to just get something new & reliable like the GR86 or maybe upgrade to another chassis.
However I talked myself out of it. I realized I spent way too many hours to not see the fully finished product. I decided to install my steering column & hvac back in the car and once I did that my motivation sky rocketed.
After that I took on the challenge of changing out the door pin bushings. I thank god I did not wait after paint to do this because this goes into top 5 list of worst things to do on this car for me. I almost lost my hearing trying to remove these pins. They were so rusted out that some of the pins could not even come out.
Next step was to disassemble the door handles and and refresh the door lock cylinder. This made a huge difference as the unlocking the door is so smooth. It feels like butter, I had no idea this was how it was suppose to feel.
Once all that was done I then took my car to paint & waited FOREVER to get it back. They lost my washer nozzles which I said was fine because I would buy some new ones. Had no idea they cost $70 dollars new. Sheesh, I'll get them eventually but my god that is expensive for something I will very rarely use. Here are the results with the car put back together (almost).
Now to the untrained eye this car probably looks perfect in these photos but all in all Its a decent paint job. Really the paint is great, its more so my ignorance. Now that I know how to do body work properly I would of done this totally different. I would of had a bigger space and I would still be working on the car. I see minor dings everywhere that I would of taking care of if I knew how to prep properly but it's a learning expereince and I'm glad I was able to take something out of this as when I get my next project which I am set on getting in the next 3 years. That will be my perfectionist build.
What are the next plans for the car? Basic stuff really. Finishing the A/C install and upgrading the turbo to a RB25 turbo. If I have time I may make a guide for the 180sx keyless entry. I have to test it out but I am almost 100% positive I found out a specific car key radio reciever will work with the 180sx and R34 GTR keyfob. I feel this would be a nice touch to the car and make it very close to a 180sx clone.
I also forgot to mention that I made a wiring schematic for using the 2001 maxima mirror controller. Its on my drive as well. Looks much better than the S13 or S14 ones imo.
Instagram: Nismo_Lk
Old 12-20-2023, 08:42 AM   #64
hiimelvin
hiimelvin is an unknown quantity at this point
Looks amazing! Keyless using the stock remote would be great if you could share when done. Also, if you're looking to replace your washer jets, just use the Ford units (PN: 8L8Z-17603-AA). They fit fine and spray a fan pattern, not the single jets.
hiimelvin is offline   Reply With Quote
Old 09-08-2024, 12:12 PM   #65
JrDarknes
JrDarknes's Avatar
Been a while since I've updated this thread. I've been enjoying the car alot this year. This has been actually the most I've driven in the past 6 to 7 years. However there is a reason for this. I'll explain later.
So last year my friend Zack found a RB25 turbo for a very good price local around the area. I decided to pick it up as its a very easy and budget upgrade for the RB20.
Changing this turbo on the RB20 is very easy but for me that was not the case.When I got this engine back in 2015 I was a bit of idiot at that time. I'm not saying Im still not an idiot now but back then I was a pretty big one. Anyway, at that time I had got the motor from Japan and as soon as it got delivered to my dads front door. I just dropped it in my car. No maintence whatsoever.
This has bit me in the ass so much in the past decade. As I've had to do all of the primary maintenace items in the car. I bring this up because as I was doing my turbo upgrade. All of my gaskets on the exhaust side were shot.
Turbo to Manifold Gasket
Exhaust Manifold Gasket
I also realized when removing the exhaust manifold that I had 3 broken exhaust studs!!! I had a huge massive exhaust leak the entire time I've owned this car and had no idea. So I bought all new exhaust studs & gaskets to reseal this engine.
I was only able to remove 2 of the 3 broken exhaust studs. The last exhaust stud at the back of the engine, I got extremely close but I broke a carbide bit inside of it and could not penetrate it. I tried drilling a bigger hole but stopped as I did not want to damage the block. For now I will be missing 1 exhaust stud at the end and used a bit more permatex copper exhaust gasket on that portion to until I get it properly fixed. Most likely will have to use helicoil.
When I put everything together. I was blown away about how different the car sounded. It had a much different tone. It sounded alot quieter. This made me realize how big the leak was. I upped the boost to 13PSI and the car rips. It's less punchier than the stock RB20 turbo but it pulls to all the way to redline which is much better than the original. Once I get a Haltech ECU & get it tuned and I'm pretty sure it will pull even harder.
Shortly after I got this done. I was involved in a car crash in my daily driver.
I was T-Boned and luckily okay. It was at a weird seattle intersection and the guy did not see me & hit me. It was pretty calm and we got each other information but when it came to filing the police report. This was just dissapointing. We tried calling the police to file a report but in Seattle its all online!! They will not come to file it which is bullshit because it just makes it a he say she say ordeal. The crazy thing is there was a police offier passing by & as I asked him to assist with filing a report. He said to just do it online.
Aboslute bullshit. Then to make matters worse, this guy insurance is just not compliant at all. I was forced to use my deductiable but my insurance company mentions they are going to continue to fight to get my money back. At first when I heard that I had no faith, however my sister was in the same scenario a couple of years ago and she actually did get her deductible back. So maybe theres a chance.Hopefully.
Anyway. With this, I had to daily drive my 240 for about 2 months. I honestly thought this was going to suck but actually I enjoyed it so much!! This is partially due to all the hardwork I spent last year with the heatblocking & sound deadning. The car was actually quite comfotarble and I took it everywhere.
I was honestly very glad I daily drove it because it really motivated me to do a few more things to the car that would make daily driving even more enjoyable. Obviously install A/C which I plan on executing this winter. I got the last piece of the puzzle (the Compressor) last month. The other thing is to have keyless entry as this car was original a base model and has no door locking system. Unlocking the doors manually, although period correct is kind of annoying when you're using this car daily.
I plan on using the OEM 180sx keyfob for this but there is a trick to do this. You must have the correct keyless entry unit. Currently you can only get these overseas by buying a 180sx, Late R34 or S15 keyless entry module. However...... I'm recieving a package next week to test a theory, but after alot of reasearch I think I found a car in America that actually shares the same keyless entry module. I'll share more info whenever I post again. & Of course I will be making a guide on this.
Lastly after 2 months of driving the 240 I finally got me a new daily. Have always been against SUV's but I get the hype. 2021 X3. Having a hard time getting used to the ZF transmission coming from a CVT. Extremely smooth and puts power down real well.
Thats it for now, but I promise the next update will be pretty good. Will be a very indepth overview of the 180sx keyless system.
Instagram: Nismo_Lk
Old 09-11-2024, 07:04 AM   #66
projectsupra
projectsupra's Avatar
projectsupra is a glorious beacon of lightprojectsupra is a glorious beacon of lightprojectsupra is a glorious beacon of lightprojectsupra is a glorious beacon of lightprojectsupra is a glorious beacon of lightprojectsupra is a glorious beacon of lightprojectsupra is a glorious beacon of lightprojectsupra is a glorious beacon of lightprojectsupra is a glorious beacon of lightprojectsupra is a glorious beacon of lightprojectsupra is a glorious beacon of light
That hatch looks so good, love the color! I probably should have went with that purple instead.
What door pin bushing kit is that? That's something I need to do as well.
projectsupra is offline   Reply With Quote
Old 09-12-2024, 04:06 PM   #67
JrDarknes
JrDarknes's Avatar
Thanks I appreciate it man. Yours is still pretty sweet honestly.
For the door hinges I got OEM Nissan.
For the Pins and gold bushings, I got them from Ebay. I could not justify buying OEM nissan ones. Were just too expensive for me.
Instagram: Nismo_Lk
