Old 01-09-2024, 09:20 PM   #1
super.trick
super.trick will become famous soon enoughsuper.trick will become famous soon enoughsuper.trick will become famous soon enoughsuper.trick will become famous soon enoughsuper.trick will become famous soon enough
Basement clean out. S13/14/15, R Chassis, JDM, OEM Stuff.
Major update 3/24/29. Sold items removed, no items added.
Hi. As the title says I'm cleaning out my basement and looking to sell the last of my Nissan parts. It's been years since I've had a 240sx at this point.
I'll ship anything on your dime (would of course prefer local pick-up) and I'll entertain offers, especially if you want to bundle stuff together.
Eventually it will all end up on eBay most likely, as it all needs to go.
You can click the images to go to an album with more/larger pictures.
S13 240sx Hatch Interior Parts
-Parcel Shelf:
$150 now $125
-Under hatch interior panel (some cracks, see pics, not visible installed):
$50 now $40
-Hatch door jamb trim:
$30 now $25
-Tie down straps for hatch floor:
$25 now $20
L&R kick panels (also have the light for the kick panel, just not shown)
$65 now $40
Lower Steering trim:
$45 now $35
Full set of good hinges (door, hood, hatch (x2 pair))
$25 now $20
S13 S14 S15 Nissan 240sx Suspension/Mechanical Parts:
S14 OEM Tension Rods w/ air deflectors: (kinda rare?)
$100 now $65
S13 OEM Tension Rods:
$35 now $25
S14/S14/R33/R34 Ball joints: (front & rear are same, have 2 pair)
$20/pair
Nismo Bushings:
-for rear uprights, front LCA, steering rack (both s13 & s14)
-check parts numbers
-selling as lot only
-55152-RS520 (x2), 55157-RS580 (x4), 54560-RS590 (x2), 54444-RS520 (x1), 54445-RS540 (x1), 54445-RS520 (x1) (not in main pic)
$125 for all
S14 Differential Housing
-ABS housing
-Z32 Diff cover with cooling fins
Pick up only, no shipping $75
Nismo Extended Lugs
-S14 front, looks like. Confirm by part number
-60mm
-40222-RS045
$50
S13 Steering U-Joint
-might fit others
$25/ea
BM-57 Brake Master Cylinder
-LHD, ABS (can convert to non-ABS)
$225
BM-50 Brake Master Cylinder
$50
S13 Clutch Master
-New OEM
$65
S15 ABS Actuator
47600-AA500
$75
S13 240sx Pedal Manual Pedal Set:
***Unfinished***
S14 clutch pedal in the S13 mount.
S14 brake pedal in S13 mount. ****Need to remount pad for brake light sensor (see pics) or have no brake lights****
(Need the curved S14 pedals to mount the covers)
S15 gas pedal
R34 pedal covers
$350
GK Tech 240sx Rack Bushings
-Filled down edges to make better contact with the rack (was only contacting on corners)
$40
Muteki SR48 Lug Bolts
-12x1.25
-Some surface rust, they've been sitting awhile
$25
Electronics:
S13 Interior Switches
-selling only as complete lot. Do not ask for individual switches
$50
HICAS Controller R34
Pigtails
28505-AA110
$45
Auto Trans S14
31036-70F00
$45
S13 Cruise Control
Computer: 18930-40F00
Engine bay components
$65
R34 GTR Keyless Entry
28595-AA000
$100
R33 GTR Fuel Control Module
pigtail
17001-24U00
$65
S14 Cruise Control
18930-70F00
$20
R34 ABS
47850-AA001
$50
S15 ABS
47850-91F00
$50
S13 Wiper Amp
28510-40F60
Excellent Shape
$25
S13 Wiper Relay
25230-40F10
Excellent Shape
$20
S14 Smart Entrance Control
28595-70F10
$35
S13 Shift Lock Control
28540-40F01
$15
S13 Rear Wiper Amp
28510-60F00
$50
Alarm/Keyless Components
$25
Huge bin of OEM wiring
I was nerotic about OEM wiring. One of my projects involved integrating a GTR and S13 harness, manual swap, adding a whole ton of options. Loads of work. IIRC, should be R32, R33, R34 GTR engine harness, R33 GTR front harness, S13 front/back/dash harness, S14 dash harness all in various states of disasembly. Its been far, far to long to make any sense of it now. Could be useful for someone I'm sure, for connectors, wiring, relays, etc. etc. MUST BE PICKED UP, 80LBS!
$100
R-Chassis:
R32 GTR Clock Spring
Has been disassembled, cleaned, lubed and reassembled.
$100
R33 GTR Fusebox Cover
$75
R33 GTR Rear Fusebox Cover
24382-27U10
$25
R33 GTR Front Diff Cover
$25
R33 GTR RB26 Charge Harness OEM
$200
R33 GTR Battery Cable OEM
$75
Koyorad R32 Radiator (Type-R?)
-Looks OEM for the most part, but performs better
-Fits S13, perfect for RB swap
-Nismo mid cap
-New OEM shroud, sensor
$350 now $300
R34 GTR V-Spec II Brembo Rear Brake Setup
-Larger rear brake setup (320mm vs 300mm) only on late model 34?s.
-All new OEM E-brake assembly
-Dixcel rotors (new)
-Brembo calipers (had some scratches, they were cleaned up in preparation for paint or powder which I never got around to)
-OEM R33 e-brake cables (new)
-Bolts right up to S-Chassis
$2250 now $1750
R32 GTR/Z32 Rear Knuckles/Uprights
-New OEM
-SPL lower shock mount bushings ($200+!!!)
-Bushing installs done right
-Has the HICAS ball joints (which can be removed)
$500 now $400
S13 240sx 180sx JDM Interior Parts:
JDM Kouki steering column surround (on the right)
$45 now $40
JDM Kouki window switches (crack to plug area, won?t impact function and hidden when installed)
$250 now $200
Thanks for looking.
super.trick is offline   Reply With Quote
Old 01-10-2024, 02:07 PM   #2
ReallyWantsA240SX
ReallyWantsA240SX is an unknown quantity at this point
I'd be interested in the OEM E-brake assembly if you're willing to part with it. If someone gives you anywhere near $2k for that rear assembly, I'd love to buy you a beer lol.
GLWS regardless.
ReallyWantsA240SX is offline   Reply With Quote
Old 01-11-2024, 08:39 AM   #3
nick_d_240sx
nick_d_240sx's Avatar
nick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymore
Argh, those louvers are soo cool.
S13
nick_d_240sx is offline   Reply With Quote
Old 01-11-2024, 11:41 AM   #4
240Zfunahollic
240Zfunahollic is an unknown quantity at this point
sent you a pm
http://zilvia.net/f/image.php?type=sigpic&userid=15347&dateline=123195  6786
Visit My Trader rating page
http://zilvia.net/f/traderratings.html?u=15347
240Zfunahollic is offline   Reply With Quote
Old 01-14-2024, 07:12 AM   #5
super.trick
GLWS regardless.
Thanks, I probably won't split because with the dust shields are a 2-year only 34 GTR part to go with the larger calipers and rotors, that's why I've got the whole assembly priced together.
Old 01-14-2024, 10:25 PM   #6
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
Willing to ship the under hood insulation to 29466? Can you pm a shipping estimate?
Thanks!
Adam
1990 240sx 5spd fastback
240Driver39 is offline   Reply With Quote
Old 01-16-2024, 03:05 AM   #7
mkhoid
mkhoid is an unknown quantity at this point
Interested in the spl UCAs text me 2407025265
mkhoid is offline   Reply With Quote
Old 01-17-2024, 02:03 PM   #8
nissanboi
nissanboi is an unknown quantity at this point
you have a pm!
nissanboi is offline   Reply With Quote
Old 01-21-2024, 09:52 AM   #9
240Zfunahollic
Legit seller. Thanks for the nismo LCAs.
Old 01-25-2024, 07:22 PM   #10
super.trick
My pleasure, thanks for a smooth transaction.
Bump, prices lowered. Starting to list stuff on eBay today, better prices here still.
Thanks.
Old 01-29-2024, 12:02 PM   #11
Club187
Club187's Avatar
Club187 is an unknown quantity at this point
sent a PM, interested in a couple bits if shipping works out
Club187 is offline   Reply With Quote
Old 02-01-2024, 05:12 PM   #12
240Driver39
Huge shoutout. Part is perfect and the packaging was even better. Almost felt bad taking it out of the box ��
Amazing seller
Old 03-20-2024, 06:07 PM   #13
super.trick
Sold a bunch, thank you to the buyers.
Updated the post, lowered a lot of prices.
Will consider offers, if you're ready to buy I'm ready to sell.
Planning to update with new pictures now that so much has sold, I'll probably have some new items to add as well.
Thanks for looking.
Old 03-21-2024, 09:08 AM   #14
CamryOnBronze
CamryOnBronze's Avatar
Trader Rating: (131)
CamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud of
Feedback Score: 131 reviews
Send a message via AIM to CamryOnBronze
Vouch for a great seller! That brake setup is very tempting...
CamryOnBronze.com
CamryOnBronze is offline   Reply With Quote
Old 03-21-2024, 12:37 PM   #15
mrnismor14
mrnismor14 is an unknown quantity at this point
Awesome seller!! Parts were packed very nicely! Would definitely buy from again!! Thank you
mrnismor14 is offline   Reply With Quote
Old 03-22-2024, 01:49 PM   #16
jmanuelg
jmanuelg is an unknown quantity at this point
check pm. paypal ready.
jmanuelg is offline   Reply With Quote
Old 03-24-2024, 09:04 PM   #17
super.trick
Updated pics, added a ton of new stuff too.
Thanks for looking
Old 04-02-2024, 12:13 AM   #18
sr_24
sr_24 is an unknown quantity at this point
I need the Hinges for the hatch
sr_24 is offline   Reply With Quote
Old 04-02-2024, 12:27 AM   #19
sr_24
PM sent interested on the hinges,
ALSO lower panel passenger and steering column key cylinder cover
