Old 02-03-2005, 02:01 PM   #1
chlatboy
chlatboy will become famous soon enoughchlatboy will become famous soon enoughchlatboy will become famous soon enoughchlatboy will become famous soon enough
Rear brakes s14
Hey guys, i was just doing the rear brakes on my s14 and after i got the brakes out, i was pushing the piston back. When doing so, i was able to push it in to an extent. This however was not far enough for me to place my brake pads. When i tried to push the piston in further, it just keeps on rotating but it doesnt go down. I am using needle nose pliers, turning htem clockwise. Not sure why the piston wont go back in. Any one think they can help me with this?
If you dont know
SEARCH!!!
chlatboy is offline   Reply With Quote
Old 02-03-2005, 03:38 PM   #2
BSeay
BSeay's Avatar
BSeay is an unknown quantity at this point
Send a message via AIM to BSeay
maybe it's seized and it wont go in any farther.... if thats the case purchase another one... i had one seize on me and it's a bitch it runs thru your pads like no other...
1995 240SX SE - Sold
BSeay is offline   Reply With Quote
Old 02-03-2005, 04:20 PM   #3
projectRDM
projectRDM's Avatar
S chassis rear calipers are known to seize up regularly. Rebuild or replace.
FORMERLY R240NA
Old 02-03-2005, 05:56 PM   #4
Drunk Bastard
Drunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really nice
Send a message via AIM to Drunk Bastard
so wait, you were pushing the piston back in with needle nose pliers? try getting a brake kit from kragen or something. there should be a tool that allows you to push the piston back in. use that, then we'll see whats up.
Drunk Bastard is offline   Reply With Quote
Old 02-03-2005, 09:13 PM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
trust me, its a pain in the ass. get the tool to seat those *its a clamp and ratchet combo looking tool* Took me 15 mins to seat the piston even when using those. Imgine how long it would have been if u used a nose plier the whole time.
CLICK HERE!!!
Old 02-03-2005, 11:47 PM   #6
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
You have to push hard and turn. It took me 15mins each caliper. There's a tool you can rent to do this. But i was too pissed off and wanted to finish it asap.
fawk.. i didn't resurface my rotors and now i have to change pads again. It's only been 10k =X
stupid car!!! /rant
driftingisgay.com
nrg is offline   Reply With Quote
Old 02-04-2005, 12:05 PM   #7
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
It's not the cars fault. It is the people who work on them that have no knowledge and only do half of the job that they actually should do. I dont understand why you were pushing the caliper in with needle nose pliers. Unless you mean turning them in?
The tool that everyone is talking about helps alot. But don't buy one of those cheap cube ones, they are garbage...
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 02-04-2005, 12:58 PM   #8
Ritz S14
Ritz S14's Avatar
Man. I just use a needle nose plier and twist them clockwise with my hands.
Ritz S14 is offline   Reply With Quote
Old 02-04-2005, 02:23 PM   #9
the head
the head's Avatar
I used the cheap cube one works fine on the nissan and every other car that has thread backs on them you just have to apply pressure just to be sure you did remove the MC cap right?
Old 02-05-2005, 01:32 AM   #10
chlatboy
no i did not remove the cap. I should try that. I did however loosen the bleeder screw if that helps any!
If you dont know
SEARCH!!!
Old 02-06-2005, 01:40 AM   #11
Twinturbozs
Twinturbozs is a well-known jackass
i had the same problem initially, but i think the dust boot on the piston was slightly off. make sure the boot folds back in accordian style.
Twinturbozs is offline   Reply With Quote
Old 02-06-2005, 03:29 AM   #12
nrg
ledzeppelin240, I know what I was doing, but i was being lazy. I figured I would have 300zx rear calipers by now.
FSM says either needle nose plier or the special tool.
I just finished my rear calipers. the tool works wonders.
I found out I have to rebuild one of my calipers. That same caliper is harder to turn than the good caliper on my right side. =\
chlatboy, why did you remove the bleeder screw? Now you have to bleed your brakes again.
driftingisgay.com
