Old 02-22-2005, 12:13 AM   #1
nissan_drifter
nissan_drifter is an unknown quantity at this point
Terrible Stalling/Idling Issues (Searched)
So when I tried to start my car minutes after turning it off today it turned over and then ran shitty for a few seconds, then stalled, fluctuating in between 600-50 RPMs, and it didnt get any better, so I leave, then search the forums, and come back, and now it wont turn over, the starter/battery/alternater are good, but it wont turn over. I thought it was vacuum issues, but now I have no clue because it isnt turning over, the plugs are fairly new, and its a 1998 KA with 127k, help please...
nissan_drifter is offline   Reply With Quote
Old 02-22-2005, 12:22 AM   #2
SimpleSexy180
no check engine light?
SimpleSexy180 is offline   Reply With Quote
Old 02-22-2005, 01:09 AM   #3
nissan_drifter
nope, no check engine light
Old 02-22-2005, 08:53 AM   #4
fastpace
fastpace is an unknown quantity at this point
Did this problem happen all of a sudden? Did you do something to the car for this problem to happen?
life is what you make of it!!!!
"well, I go out, I do the practice, I think about it and I concentrate on one small thing I can change that will have an effect. I make that change then I go out and drive to my maximum." -Ayrton Senna
fastpace is offline   Reply With Quote
Old 02-22-2005, 11:16 AM   #5
nissan_drifter
happened out of nowhere
Old 02-23-2005, 02:51 AM   #6
idlafie
idlafie's Avatar
Did you attempt any troubleshooting efforts, like 1). checking the fuel pump to see if you are actually getting gas, 2). Checking the spark plugs for spark. If you are not getting either, then it's possible that the ground wire above the oxygen sensor could have shorted out. Cut the ground wire grommet and resolder all the wires to the new grommet then rebolt the new grommet to the same ground point. A shorted out ground wire will cause No Start problems. I had this problem myself a while back...LOOONG story...
Anyhow, hope this helps.
ID
