Old 02-28-2005, 11:14 PM   #1
sil_eighteeh
sil_eighteeh's Avatar
sil_eighteeh is making a name for him/her selfsil_eighteeh is making a name for him/her self
Send a message via AIM to sil_eighteeh
17" gram lights 57s
ok guys i need some help on rim fitments. I have a s13 w/ 20mm wide fenders in front and stock rear and on tein flexs. i need to know if 17x7.5 +22 and 17x8.5 +22 Gram Light 57s would be a good size for my car. would they sit flush?
sil_eighteeh is offline   Reply With Quote
Old 02-28-2005, 11:24 PM   #2
nehoye
nehoye is an unknown quantity at this point
Yes thet will be.
22 offset is the max you can go for stock fenders
nehoye is offline   Reply With Quote
Old 03-01-2005, 04:02 AM   #3
sideviewcivic
sideviewcivic has a little shameless behavior in the past
Send a message via AIM to sideviewcivic
dood your post count is very low to be offering such advice like wheel fitment. with a 20mm over fender. those wheels will sit so damn sunken its not even funny. Sil eighteeh do some searching on here to get an idea of flushness and around what offset will work with that 20mm overfender you have. On a side note: 17x9 +15 fits upfront with a 20mm fender IIRC but flushness is the key. coilover clearance you can have with a +35offset. just get everything in a lower offset.
sideviewcivic is offline   Reply With Quote
Old 03-01-2005, 09:44 AM   #4
mk20116
mk20116's Avatar
mk20116 is an unknown quantity at this point
good place to start.
http://www.zilvia.net/f/showthread.php?t=44300
1....2....3....4....
mk20116 is offline   Reply With Quote
Old 03-01-2005, 09:56 AM   #5
mr_240sx
mr_240sx's Avatar
offsets confuse me, i thought i finally understood offset and then next thing i knew, i was all confused again!
mr_240sx is offline   Reply With Quote
Old 03-01-2005, 10:33 AM   #6
omen2853
omen2853's Avatar
omen2853 is an unknown quantity at this point
agreed, that size will be battleship sunk. also....sideviewcivic...17x9+15 will fit on stock fenders, you dont need a 20mm. just roll them and run a 215/40.
as to the poster... if you like the 57s you should get the 17x9.5's. you could probably get away with 17x9.5 +12 on stock fenders with a stretched tire....so the 20mm over fenders should be ok (20mm is like adding an additional 3/4 inch.to the fender).
as for coilover clearance i dont think youd have any problems. but do some more research.
omen2853 is offline   Reply With Quote
