Old 02-28-2005, 10:16 PM   #1
tallic_red240sx
tallic_red240sx has a little shameless behavior in the past
Low compression all cylinders 95ka24de
Had a low mileage 95 ka24de engine put in my 91 240sx.
The shop that put my engine in did a compression test on the new engine installed, and for some reason got 96 across all cylinders.
They said it was getting spark and that the oil is fine and whatnot...My question is,what would cause that?The shop said that that the timing chain may have jumped, but they dont know for sure.
Also, they had to take out the internal distributor and put the internal dist. from my 91.....
If someone could help me out, that will be greatly appreciated..
tallic_red240sx is offline   Reply With Quote
Old 03-01-2005, 12:54 AM   #2
Flybert
Nothing wrong with using S13 distributor on S14 motor. You have to do it that way because the s14 distributor has a built in coil. As for the numbers, was the test done on a warm engine?
Old 03-01-2005, 07:48 AM   #3
X1nom3D
X1nom3D's Avatar
X1nom3D is an unknown quantity at this point
does the exhaust fumes smell normal? or try smelling the intake, any sign of fuel leaking out before cumbustion?
X1nom3D is offline   Reply With Quote
