Old 03-01-2005, 10:08 PM   #1
dephrag
dephrag is an unknown quantity at this point
Starter issues
Hi guys..
I'll keep it short and sweet..
Car's not starting.. simply very fast clicking. Had the battery tested, works 100% so oviously it's either a dead starter or a bad ground right? I checked my battery connection and the engine ground connection and they are just marvellous. I can't get to the starter cause I can't get under the car. So it's more than likely a bad solinoid in the starter right? I was able to get it to start a couple times, after either a bunch of clicks or I was lucky once and it just started right up, but now it's not being nice at all. Also every time it's clicking its resetting a fuse or something because my clock resets and my cd ejects..
Sound like a typical starter problem???
Thx!
dephrag is offline   Reply With Quote
Old 03-01-2005, 10:12 PM   #2
NakayamaKiyoshi
NakayamaKiyoshi is an unknown quantity at this point
sounds like the one way clutch on your starter pinion finally went out completely
IMG exceeds forum limit of 400x200
NakayamaKiyoshi is offline   Reply With Quote
Old 03-01-2005, 11:50 PM   #3
s13gonwild
s13gonwild is an unknown quantity at this point
yes its the starter.
good luck
s13gonwild is offline   Reply With Quote
Old 03-02-2005, 07:46 AM   #4
AenjukuCar
AenjukuCar's Avatar
AenjukuCar is an unknown quantity at this point
Send a message via AIM to AenjukuCar
i have a spare starter for sale let me know
AenjukuCar is offline   Reply With Quote
Old 03-03-2005, 08:55 AM   #5
dephrag
Well I took my starter off, to get rebuild if it's possible, but if not, what kinda of replacement starter would I get since it's an SR? I checked the parts listing in the FAQ, but it's not listed? I'm guessing I can use one from a sentra???
Old 03-03-2005, 10:43 AM   #6
valencia_ryan
valencia_ryan is an unknown quantity at this point
just had the same problem and got one from venus auto for like $55 shipped and got it in 2 days. was way cheaper then on ebay. hope that helps
valencia_ryan is offline   Reply With Quote
Old 03-03-2005, 05:54 PM   #7
drew935
drew935's Avatar
drew935 is making a name for him/her selfdrew935 is making a name for him/her selfdrew935 is making a name for him/her self
also check your starter relay. Mine was bad even though i changed and rebuilt the starter. Wasted $160. I took off the relay and used a jumper plug bten the wires to connect it. Right now, my car starts w/o having to step on the clutch. Turn the key and start .
I'm driving fast
-drew
drew935 is offline   Reply With Quote
Old 03-04-2005, 08:15 AM   #8
dephrag
Hmmm..and where do I find that relay?
