Old 03-01-2005, 09:25 PM   #1
S14Swap240sx
S14Swap240sx is a well-known jackass
Toemi Camshaft question
Both cams are 264 10.5
they are said to be tomei cams, but i wanted to know if there was anyway to guarentee that these are toemi cams.. we can start with did they even make a cam to that spec. the reason there is no box or what not, is becasue they are used, but in great shape! and for there low price its worth it.
what more information do you guys need here? ill double check the specs, and try to get pictures of em
S14Swap240sx is offline   Reply With Quote
Old 03-01-2005, 10:11 PM   #2
dunno
dunno is an unknown quantity at this point
Send a message via AIM to dunno
I'd assume this is for an SR20DET, but even if it's not, I checked SR20, RB20, RB25, and RB26 for you. Tomei does not currently manufacture a camshaft for any of the former with a 264º duration, intake OR exhaust. For the SR, they offer the Poncam with 256º, and the Procam with a range from 256º to 280º, but never pinned at 264º. Coincidentally, the lowest cam lift they manufacture for the SR is 11.5mm. So it comes down to three options.
1) The seller has the numbers way off.
2) These are not Tomei cams.
3) These are older production Tomei cams that are outdated and no longer sold (unlikely).
Pictures would help.
-Matt
dunno is offline   Reply With Quote
Old 03-02-2005, 07:48 AM   #3
the head
the head's Avatar
tomei does make 260 cams but the lift is 12 not 10.5
Old 03-02-2005, 09:06 AM   #4
S14Swap240sx
alright, well thats all stuff that can be measured, so ill try to confim that asap.. but as for marks on the cam shafts, does anyone own a set of tomei cam that dont have there name cut into them or something..
its for a s13 sr
Old 03-02-2005, 09:13 AM   #5
the head
the head's Avatar
sometimes there is a logo or somthing stamped into one end not sure on tomei but it could give ya some info
HKS makes 264 but i am not sure of the lift should be 11 or lower b/c IIRC it doesn't require springs
Old 03-02-2005, 09:30 AM   #6
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
264 10.5mm lift are the dimensions of the HKS cams and some others
wootwoot is offline   Reply With Quote
Old 03-02-2005, 08:57 PM   #7
S14Swap240sx
http://www.dreamchaos.net/~shevon/mi...mei%20cams.JPG picture
Old 03-02-2005, 11:32 PM   #8
SPEC_R_SILVIA
SPEC_R_SILVIA is an unknown quantity at this point
tomei puts there sign on there cams i know that for sure because i have some friends that bought tomei cams
[IMG]
SPEC_R_SILVIA is offline   Reply With Quote
Old 03-03-2005, 07:43 AM   #9
the head
the head's Avatar
stampings for brands would most likly be on the end of the cam
Old 03-03-2005, 08:49 PM   #10
SPEC_R_SILVIA
yup nailed right on the head
[IMG]
