Old 03-06-2005, 07:09 PM   #1
NismoDan
NismoDan's Avatar
NismoDan is an unknown quantity at this point
My car likes to steer itself....
My S13 likes to go all over the place when I let go of the wheel.
It feels like what happens when a car needs an alignment - it drifts all over the place.
The thing is, it does it to BOTH SIDES!!
It seems to randomly steer to either the left or the right when I let go, but never one side consistantly.
Any ideas?
Forgot to mention, I just replaced my worn out T/C rod bushings with Whiteline polys.
C4L #34
NismoDan is offline   Reply With Quote
Old 03-06-2005, 08:00 PM   #2
mrmephistopheles
mrmephistopheles's Avatar
did you buy your car from Knight Industries?
Originally Posted by PHLIP
Old 03-06-2005, 08:14 PM   #3
007jpang
007jpang is an unknown quantity at this point
did you get a nismo power brace??
April 24th, 1915
http://www.shockdrifting.com
007jpang is offline   Reply With Quote
Old 03-06-2005, 08:18 PM   #4
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
Worn tension rod bushing will cause that in severe cases.
If your car drifts by itself leave it alone and enjoy the ride.
blu808 is offline   Reply With Quote
Old 03-06-2005, 08:24 PM   #5
m0rex
m0rex's Avatar
m0rex is on a distinguished road
I dont think a nismo power brace or bushings are a problem since i have both and i dont feel the difference when im driving in a straight line. It can be a lower control arm though, and if it aint then its your ball joint on your lower control arm. If the ball joint is loose it jerks to the sides really violently and if you been driving around like that its probably stripped (it happen to me when i took my suspension apart to put my nismo power brace but i've changed suspension parts so much i can take out my whole suspension in 4 min).
If its none of this or if you are sure its not wheel/tire or anything thats loose related then what have you hit/changed that could of damaged the suspension?
m0rex is offline   Reply With Quote
Old 03-06-2005, 08:27 PM   #6
The Hamsterball
The Hamsterball's Avatar
The Hamsterball is making a name for him/her selfThe Hamsterball is making a name for him/her self
Shit.. how are we we supposed to know what exact part is causing this.
Get under there and check it out.
Go crazy and tighten front suspension component bolts. See what's missing, what's torn (bushings/etc), what's loose.
Your car probably needs an alignment. Have you taken the time to go to an alignment shop to get a *FREE* estimate?
Go do all that and you'll be sure to find out where it's stemming from.
White '90 S13 Fastback (SOLD in '07)
The Hamsterball is offline   Reply With Quote
Old 03-06-2005, 09:10 PM   #7
thx247
thx247 is an unknown quantity at this point
sounds like somethings b0rked under there...maybe a check of the suspension is in order.
Finally down to 1 car again. Thank god.
thx247 is offline   Reply With Quote
Old 03-06-2005, 09:21 PM   #8
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
my car does this too..i always figured it was cuz my offsets, w/ such a wide track i figured it was just more sensitive to grooves in the road surface
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 03-07-2005, 02:21 AM   #9
blu808
blu808's Avatar
hmmmmm cough cough tensioncaugh hmm rodhmm bushuhh huh ings,
Old 03-07-2005, 02:41 PM   #10
Salty_X
Salty_X is an unknown quantity at this point
It's probably just the banking of whatever road you happen to be driving on at the time.
Salty_X is offline   Reply With Quote
Old 03-07-2005, 03:12 PM   #11
NismoDan
NismoDan's Avatar
That's the second time youve mentioned tension rod bushings, but I explained in the original post that I just replaced those.
It was doing it before with the shot ones, and still is with the Whitelines.
C4L #34
Old 03-07-2005, 03:41 PM   #12
blu808
blu808's Avatar
Thats odd. Usually 9 out of 10 times it is stock worn tension rods changing the caster back and to front while you are driving.
Old 03-07-2005, 03:49 PM   #13
papershot
papershot's Avatar
papershot is an unknown quantity at this point
Send a message via ICQ to papershot Send a message via MSN to papershot
road could be banked, tires could be following grooves in the road, or most likely your alignment is bad.
did you ever get a new alignment after you replaced the tension rods?
papershot is offline   Reply With Quote
Old 03-07-2005, 03:59 PM   #14
S14DB
AFC #1
S14DB's Avatar
CHeck your caster angle.
Old 03-07-2005, 07:03 PM   #15
mrmephistopheles
Fuck, man.. nobody even acknowledged my joke.
Old 03-07-2005, 07:05 PM   #16
S14DB
AFC #1
S14DB's Avatar
Meh, Sounds more like Herbie to me.
Old 03-08-2005, 12:30 PM   #17
blu808
blu808's Avatar
I just didnt want to say anything.
Old 03-08-2005, 12:57 PM   #18
the head
the head's Avatar
might want to check the tie rods. Could be EXTREMELY warn hub bearings ball joints or torn control arm bushings
